Hello I have a 2006 XA I was Filling the Freon and was at full when I was goin to remove it then the compresor stoped and no more cool air. I have check all fuses all looks good. HELP!!!
  • d5bust Jul 12, 2009
    Thank you. How do I fix That???? It is hot here in AZ
    Champion:
  • 233 Answers
If you put too much refrigerant in it the high pressure switch may have tripped
Posted on Jul 12, 2009
  • Dan Favata Jul 12, 2009
    on a trane unit there usually is a manual reset high pressure switch, with a red button on it, trace out the small wires that come from the contol panel into the compressor chamber, (with power off!) you should end up at a switch that is screwed on the end of a tube with a red button, push the button, it should reset, (if the pressure is below the switches setpoint)
  • Dan Favata Jul 20, 2009
    the pressure switch will only trip if there is too much refrigerant in the system, of if the outdoor condenser pressure is too high, this can be caused by a bad fan motor, a dirty coil or blocked airflow, as well as many other things these are the most common, clean the coil (inside to out) with the power OFF! let dry, adjust the charge to factory specs.
95 Lincoln Town car A/C is blowing only hot air.
You can try stop leak, but don't expect great results. If the leak is big enough to lose more than 8 oz in a few days, you have a major leak.
And using more than one can of stop leak can cause problems in the system.
Jul 27, 2012 | 1995 Lincoln Town Car
Refrigator not cooling.
Are you filling your freezer to full that it isn't able to cool? Maybe you just need to have it serviced filling it with Freon.
Jul 09, 2012 | Refrigerators
Ac doesn't turn on - 2006 scion xa
low coolant will not allow the compressor to come on it is a safety so you will not damage the compressor
May 30, 2012 | 2006 Scion xA
I turn on a/c the light is on but ,no cool air and I see the compresor it´s off .
system is low on freon, system has a low psi cut off switch when the freon gets low it will not allow the compressor to turn on.
Nov 14, 2010 | 1995 Toyota Camry
2006 MAGNUM REAR A/C NOT GETTING COOL
Hello, the problem with your rear a/c not getting cool is that the A/C is short of freon and your AC may need re- filling,and if you continue to running your AC,it can cause damage to the AC compressor, the re- filling needs to be done by qualified personnel.
Thanks
Aug 17, 2010 | 2006 Dodge Magnum
A/c
if you just added cans on freon to the system without gauges to see how much is in it,you have it over full, if the system is over full, it cant curulate .if it dont curulate it wont cool, i had one that was to full ,the hotter the outside temp got it stopped cooling, when it was 80 degrees it done fine when it hit 90 it stopped curulating,no cool.check it with gauges,check a/c fuse in compressor ,hope this is some help to you, thanks robert b.
Jun 28, 2009 | 2006 Toyota Tundra
A/c is blowing hot air my brother check it for me and said freon iz full so what can be the big problem with this truck i got it brand new and paid almost 45,000 for it for this luxry car to just mess up...
I had the same problem I went and got the compresor replaced I bought it for $170.00 but my husband replaced it was about $250 (compresor, freon, ) total and now it works fine
Jun 27, 2009 | 2001 Lincoln Navigator
2001 Honda Odyssey Ex Air Conditioning Not Cooling
Hi, my best advise is to have your air check for freon leaks ,low freon causes the compresor cluth to stop working ,this can cause the air to blow hot .......
Jul 10, 2008 | 2001 Honda Odyssey
Refigerator leaked water slightly then stoped cooling
Yes try to turn with a screw driver if possible. If it start working replace timer. If not it can be low on freon you would see frosting but no cooling.
Jan 07, 2008 | Magic Chef CTF2125 Top Freezer...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
