Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
No water from the faucet over a minute when the water pump starts
Recently, when ever the water pump starts, there is no water from my house faucet. There are a water tank in the basement. Can somebody give me a solution?
  • 832 Answers
First and foremost, check if your water pressure is between 20 to 40 psi. If it is, there is no reason why
you could not have water in your faucet. Check your
faucet and your pipelines for closed valve or a clogged
pipeline. However, even if the water pump pressure is
only 10 psi, it should reach your faucet. 10 psi pressure is equivalent to 23.1 feet vertical height.
So, please check it up and get back to us by e-mail.
Posted on Oct 26, 2009
How do I prime my flotec 4022 pump
A number of Flotec pump manuals are available here: http://www.flotecpump.com/ResidentialResourcePage_resourcepage_ownersmanuals.aspx . The site lists a FP4022-10 pump with the direct link to the manual here: http://www.flotecpump.com/resources/images/514.pdf .
For this type of pump, there should be a priming plug or priming tee. Remove the plug (or tee) and pour water into the pump. Keep adding water until the pump and all of the piping to the well is full of water. If a priming plug or tee was also added on the suction side of the pump, open that section and fill all of the piping on the suction side with water. Replace the plugs/tees then open a faucet in the house. Start the pump. After 2-3 minutes, turn off the pump if no water has come through the unit. Add more water through the priming plug or tee (or multiple plugs and tees). Then repeat closing the priming ports and start the pump after opening a faucet. Once the pump is actually pumping water, turn off the open faucet. Wait for the pump to shut off once it reaches full pressure. Open one or two faucets to check that the pump is properly sensing the pressure changes and maintaining system water pressure.
If the unit didn't pull water from the well, check the piping for air leaks. See the full trouble-shooting guide in the manual. Page 9 has the priming information and page 10 has the trouble-shooting guide.
I hope this helps.
Aug 27, 2016 | Flotec Plumbing
New faucet(pump handle style) at times has air in line. No interruption in water flow and old faucet did not do this. Blows water on user
Sometimes air enters the street mains when people use an air compressor to winterize a house by blowing water out of the house and back to the main. Run all faucets in house for 5 minutes. That should purge all the air out.
Aug 27, 2016 | Plumbing
Water pump for the house keeps re-cycling, without using water
IS THE TANK WATER LOGGED? THERE HAS TO BE SO MUCH AIR IN THE TANK TO KEEP PRESURE.
Nov 28, 2013 | Goulds Pumps J and JS Series Pump nozzle...
Have a pegasus shower faucet an it knocs every time you turn the hot water on in any part of the hause
Sounds as if you have air in the pipes.
To solve this you will need a piece of hose that will fit over the ends of your hot and cold faucets in the kitchen (or other lowest faucets in the house) - fix it on tightly with hose clips and open both faucets fully. Wait 5 minutes or so before turning off hot water faucet first.
If that hasn't cleared it repeat the process but after 5 minutes turn on your shower faucet and see if it splutters as the air is forced out. You may have to do this with other faucets in the house too. Close each one off once the water runs evenly without air in it.
If that doesn't work you will need to drain your hot water system down completely. Turn off water supply at the hot water cylinder (or rising main if you have a tank-less system) and open all faucets until water stops flowing. Close each faucet about 2/3rds then turn on water supply again. Wait for each faucet to get a slow but steady flow. Going round each faucet in turn gradually open each on a little bit more until all are running fast and even and all the air has spurted out. Now go round each faucet in turn closing each one down a bit at a time until they are only dribbling a small amount. Turn all faucets off.
Feb 17, 2011 | Plumbing
I have a model 109163. I'm trying to pump water from a creek. The suction hose is about 6 ft below the pump and 12ft long. The output hose is running about 300 ft at a gradual incline to about 10 ft. My...
In order for the pump to **** up water, it must discharge air. Try this. Install a hose bibb (faucet) in the discharge line over top of the pump. Fill the pump housing with water, turn on the pump and open the hose bibb/faucet until full water flow is established. Almost all air should be out of the pump and suction line at this time. Now when you close the hose bibb/faucet, the pump will have plenty of pressure to fill the long discharge line.
Suction line should be 2-1/2 inch if that is the pump suction size.
What size is your discharge line?
There should be a check valve/foot valve on the end of the line in the creek to keep water in the pump once it is primed.
Gary
Dec 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
My pump comes on and presurizes about every 20 to 30 minutes, when there is not water being used in the house. If I shut the valve off from the pump to the storage tank the tank will stay presurized and...
When you hear water running, it is usually in a drain. You probably would have noticed a leaking faucet, so it's probably a toilet. Try shutting off the supply pipe to any toilet you suspect and see if that stops the pump. Then you have to fix the toilet.
I hope this helps. Thanks for using FixYa, and good luck.
Al K
Mar 24, 2010 | Tetra Plumbing
Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
How to fix a sulfur smell from hot water side of faucet.This started when we replaced an old faucet with a new one.
Probably coincidence, but that sulfur smell is likely from your water heater.You'll either have to shut-off power, or gas, to water heater, and drain it down, then re-fill it, or leave hot taps on, and let it flush itself out. If you have a way of introducing bleach to line coming in to house, such as a pump or something , you can do that to help flush that smell out of water heater, otherwise, flushing or draining may be your only option.
Jan 07, 2010 | Delta Victorian 2155-SSLHP Bar Two Handle...
''no water''
I too had the same problem as you with my pipes freezing, but my heat was the culprit. Basicly the problem was the same. I turned the water on in the sink and when the water thawed there the pump started and oh my god I had broken water pipes in the house under the counter, so I turned the main water valve off, or the pump from the breaker box for the well. The difference is that if you turn the well pump off then the water runs until the pressure goes down. If you turn the main water off it will stop sooner. I fixed the pipes under the sink and behind the dishwasher started to leak, Fixed that and again turned on the water again at the main valve. Ask where your main water lever is. My water started to run in the sink area, but the drains were frozen, I put a heater under the house and heated up the pvc pipe that was still frozen. Of course the toilet..... When it got alittle warmer and the heat on the pipe, things broke loose. The plumber was no where to be found because they were so busy, this worked for me and people had great ideas for me to try. When the water and the pump were turned back on all leaks were fixed and things are back to normal. I am now wiser...I hope this story helps somewhat.
Jan 17, 2009 | Plumbing
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
268 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
