Question about Xerox Phaser 8500/DN Printer
Printer error: 09,038.46:935
I have a printer error: restarting the printer doesn't hep. Any suggestions?
I had 2 cracked black ink solids in the loader. They have been removed and the printer asked for more 'whole pieces'. I had to since re-order the ink, but I'm pretty sure the error has been resolved now. Thanks for your help!!!
Posted on Nov 29, 2007
    Novelist:
  • 208 Answers
Printer Error 09,035.43 through 09,038.46 Ink Stick Count Faults and False Ink Out Messages .
May need a new ink loader.
May just be a weak spring loading the ink, or you have a ink stick that is just stuck , not pushed into position.
sideways. Or did someone try to load a piece of a stick?
Posted on Nov 28, 2007
3 Suggested Answers
  • 2072 Answers
SOURCE: xerox phaser 8560 ERROR: 09, 038, 46:15112
Yep. One of your ink sticks is stuck in the ink loader and not advancing down to the bottom of the ink loader.
Look where you add the sticks, I think off hand that .46 means its a black stick, but anyway, one stick is broken, cracked, twisted or otherwise for some reason not sliding down the loader.
If you have to remove them, take a screw, a drywall screw is best to twist into the ink block and slide it back and out to reload.
Posted on Dec 21, 2008
  • 50 Answers
SOURCE: During its warming up cycle,
Here's what the service manual has to say:
9,035.43 through 9,038 (8500/8550/8560 only): Ink count sensor flags are
stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41,
where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out
Sensor located at the forward end of each ink channel of the Ink Loader. The
sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This
can lead to false Ink Out messages as well as Ink Stick count faults. Using
8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick
count faults.
Posted on Jul 18, 2011
Printer error
First confirm if the printer is recognized by your system,and check the printing history to see if there is a queue. If there is, delete them and restart your system. This time, make sure it\'s recognized, then resend your instruction to print.
Jun 12, 2013 | Office Equipment & Supplies
Canon 1p2770 ciss ink cartridge is not recognized
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Oct 27, 2017 | Canon PIXMA Office Equipment & Supplies
Okidata B4600 error message #132 on two printers. What does this error mean. The printers will not go to off line.
Error 132:
LED Head Missing, Color:Magenta
When magenta LED head connection cannot be detected
Solution:
You should first try to restart the printer.
If that doesn't resolve the problem, the ribbon cable is probably disconnected from the print head.
The led print heads are four assemblies that hang down from the lid of the machine when you open it. Make sure they are properly connected.
Sep 14, 2011 | OKI B4600 Printer
Spooler service is not running Model Z32
There are several ways to resolve printer spooler error, probably because there are many variations of this error.
The error caused by faulty software can be resolved by deleting all the information found in the directory.
Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon.
Find the service labeled Print Spooler, highlight it and restart the process. If that doesn't work, the program might be corrupted.
Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window.
On this window, scroll down and click "Print Spooler". Check its setting and turn on automatic mode.
Click Okay, and restart the machine. If you're lucky, this might be all you have to do.
Still doesn't work? Navigate to the Add/Remove Programs screen of the Control Panel.
Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved.
Download the latest copy of your printer's software from the manufacturer and reinstall it.
May 17, 2011 | Lexmark Office Equipment & Supplies
Error message spooler subsystem app not working
Apr 12, 2011 | HP Photosmart C4480 All-In-One InkJet...
The red led of hp laser jet 1300 printer is blinking and does not print
Hi there
If stops only blinking and jsut press the resume button. Also, open and close the cartridge door to resume printing.
If not I believe the spooler print had stop and you need to restart it. Download, unzip and install this software. http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xeroxand-everything-else/ . It will heps you fix spooler print to restart.
I am sure it will solve your problem.
Feb 11, 2011 | HP LaserJet 1300 Printer
Error 5100, paper sticks, printer stops
Hi There
TrySolution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Hope it will hep
All Best:Pineworks
Jan 25, 2010 | Canon Pixma MP450 All-In-One InkJet...
Black type doesn't print; everything I know hasn't helped
Hi!
Sorry about the delay in getting back to you. The problem has been taken care of. 1. The black cartridge was evidently dried up somehow. 2. The installation of the software (drivers & repair) (blue tooth or whatever) has completely fixed the problem. So whatever it was I paid for and downloaded at your suggestion (my ignorance of the jargon is minimal). However, what counts most: with your help, everything is operating and working as it should. Many Thanks! Raymond C. Root
Apr 01, 2009 | Dell Office Equipment & Supplies
RICOH AFICIO AP3800C
This normally suggests to the transfer belt it is possibly worn and the transfer unit will need replacing
Hope to be some hep
Jan 02, 2008 | Ricoh Aficio AP3800C Laser Printer
Xerox Phaser  8500/DN Printer Logo
229 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
