Question about HP Color LaserJet 2600n Printer
Ink is bleeding on sides of paper and appears to be leaking inside printer. Is this something that can be fixed?
    President:
  • 3,085 Answers
What ever color is leaking is a bad cartridge.
you must replace that cartridge.
Posted on Jul 13, 2009
Ink leaks and pools in right back paper tray and leaks onto desk
it sounds like your collection assembly is full. this is not something you can do anything about. it must be replaced and it will be costly. you are probly better off to replace it
May 18, 2017 | HEWLETT-PACKARD Office Equipment &...
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Leaking black in from the bottom of the printer
actually your printer needs servicing but for temprory solution.take a bunch of tissue paper .keep the printer on and the printer cover open so the cartridge will be in the center.then with the tissue paper place it internally on the side from where its leaking.the sponge which collects the wastage ink is at present got full and now it does not have the capacity to soak the ink.so its leaking.as you will place the tissue papers the ink will be soaked by tissue paper and the sponge will again become bit dry to soak more ink.but its the temprory solution.to make it permanent get the printer serviced and sponge replaced.the problem is not all serious ,its common.every printer comes to this stage after certain usage.and the servicing is the solution.a local printer repair shop also does the servicing job .
hope this helps.
thanks.
May 03, 2009 | HP Photosmart 8250 InkJet Printer
Toner leaking ink on one side of paper pretty bad
There could just be a lot of toner inside the printer, but it could also be the drum unit (which also collects the waste toner) is so full that it is leaking.
This typically happens when the 'replace drum' indication is reset without actually replacing the drum.
If you have reset this without replacing the drum, and the print count is in excess of 30,000, you probably just need to replace the drm unit.
Mar 05, 2009 | Dell Laser 1720 Printer
I have a black line of ink on the back side of the paper when I print anything. It fade through to the front. The line goes down the middle of the paper and is about 1/4 in wide
Cause: Possibly a leak in an ink cartridge. Pull all of your cartridges and inspect for leaks....it will be obvious and you will probably get it all over everywhere if you are not carefull, so be prepared to immediately toss it in the waste bin.
Solution: Sounds like you have ink (wet?) inside the paper path on one of the rubber rollers. It sounds like it is so saturated with ink that this will continue for a long time until it either runs out or you replace the roller.
Look for the roller that is where this line appears. Using another piece of paper or a paper towel soaked with alcohol (rubbing), touch it and see if ink doesn't appear on the paper. If it does then you might be able to clean it by continuing to soak up the ink on scrap paper by pressing it out of the roller. It won't completely fix the problem and it won't do it right away but it will get it started.
Jun 21, 2008 | Office Equipment & Supplies
Kodak g600-paper jam
In the book they say to turn off and then turn back on that is supposed to work! ( keep trying that ) try to find a repair shop I took mine apart fixed it but not something I would do again.
May 01, 2008 | Kodak Easyshare Printer G600 Thermo...
HP Color LaserJet 2600n Printer Logo
328 people viewed this question
Seeker5211
Seeker5211
