Question about Philips Magnavox 27MS343S 27" TV
I have 50 in plasma phillips magnavox 50mf231d-37, will not come on red light flahses 4 times
  • 36 Answers
This is some info that some one else had found
get a memory stick( flash drive) and up load their soft ware from their site. I plug the stick into the computor and uploaded the software. I then plugged the stick into my TV on the side. A screen came up and the software loaded on the TV successfully. The red light then turned to green. However, I now have to unplug and plug the TV several times for it to turn on. It works fine but once the TV is turns on, but when I turn it off and it cools for a while I have to repeat the same proceedure off plugging and unplugging
Posted on Jul 12, 2009
SOURCE:
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
Magnavox plazma 50 inch flat screen wont turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Televison & Video
We have a Magnavox, 50 inch plasma TV, model 50MF231D/37. Recently when the TV is powered off and an attempt to power it back on again has been made, we get a red blinking light. The light blinks six...
Your problem is caused by a power supply issue it sounds like a capacitor is leaking or has vented and will need to be replaced if your comfortable you could check the power board for a can shaped electroletic cap that has vented it will be puffed up on the top the value is printed on the side you can or have someone replace it that should take care of your problem the power board is the one where the AC cord plugs to or leads to
Dec 10, 2009 | Televison & Video
I have a Magnavox 50MF231D/37 plasma tv that won't turn on. I have to unplug it and let it sit. The green LED light changes to red and flashes. I upgraded the software but still have the problem.
you have some bad caps on the power supply board these can like devices will have a puffed up top where it vented the value is written on the side of the part
Nov 24, 2009 | Televison & Video
I have a 50' Plasma HDTV and when I turn it on
First thing to try is replace any swollen capacitors on the power board.
Nov 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
50" Magnavox Plasma TV will not turn on - Red LED blinking 4x
When you have the red light that blinks four times on the 50" Magnavox Plasma Model 50MF231D/37, you should look for the capacitors on the power board in the center of the of the TV. Look for two 3300uf, 10V, 105c capacitors that have a build up of pressure that has caused the top of the capacitor to look rounded instead of the flat top that will be on all of the other capacitors. Changing these two capacitors fixed the problem of the TV not coming on.
I had more trouble finding the capacitors than changing them. I could not find them locally so I went to an on-line electronics supply store where they were $1.65 each and $8.99 to ship.
Jan 03, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Philips Magnavox 27MS343S 27" TV Logo
472 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
