Question about Dometic Rooftop RV Air Conditioner
My attic air conditioner will stay at 81 degrees in the hottest part of the day only when it is sunny when it is cloudy it works fine I have a small 900 sq foot ranch
    President:
  • 3,433 Answers
You mention the attic in specific. Is this space now occupied as a living space? This is a similar problem with heating also.. Keep in mind that heat risesand of course cool air drops. So in cooling you are working from the floor upward and in heating you are ceiling downwardOn nice warm sunny days the heat is constantly replenished through the roo, which is seldom insulated, Unless the warm air has somewhere to go, it will stay where it is and once your ac brings the cool air layer to it's, exchange level it will only exchange and keep cooling the same air.,and what warm air that is below is constantly rising if not caught in the air stream to be cooled. In reality, Itwould be better to have the Air conditionr upstairs. but as it is right now, You need a means of venting the hot aitr to the outside. A gable fan or even a small window in the atticwould work. That's another thing, with no venting upstairs ther is no air current to carry the heat dow the AC unit. Venting will also lower your evergy bill and give your AC unit a break. Experiment with your car. Turn on the AC full blast with all the windows closed on max cool. Takes a while to cool the interior down, then open the window around 1" to 2" and you will see right away the difference it makes.. You can't drive the house down the road, but the car AC will actually work better going down the road. Most inexpensive remedy is to put a gable fan in, if it's now a bedroom,, install a 12x24 vent window. Then I truly believe you can defeat your problem.Even if your AC is underrated, it will to help it a little. Good luck and best wishes
Posted on Jul 13, 2009
    Champion:
  • 233 Answers
If the difference in termperature is between 15 and 20 degrees between the inlet and outlet, the unit is doing all it can and is undersized. if not check for airflow problems, filters, dirty coils etc. and if that is all good, then there may be issues with the refrigerant charge
Posted on Jul 12, 2009
I have a Ruud air conditioner model #13AJA36A01757. The temperture out of the vents is only 70 degrees while it is running. Outside unit, low side is very cold, and the high side is not hot, not even...
If your vents are in the floor, you need to inspect your return air ductwork, you may have some air leaks pulling hot attic air in thru the vents. If the supply vents are in the floor, the return duct may run through your attic, if the duct work is uninsulated or pulled apart, it will pull hot air thru the return, causing a mixture of cold and hot air, giving you a warm air movement through the ductwork. Many service men will not catch this problem. You need to turn the unit on, go up in the attic and visibly inspect the entire return air. I hope this helps you. mark
Aug 14, 2011 | Ruud Heating & Cooling
The air conditioner kicks off every few minutes on very hot days
Check the condenser coil, it sounds like it's dirty. If not then the condenser motor may be bad, running slow or not running at all.
Jun 29, 2010 | Whirlpool ACC108PS Air Conditioner
My air conditioning units work. They are cooling. The thermostats say 76 degrees. The problem is the hot dry smelly attic-like air that is constantly circulating and blasting down on me from the air vents....
the techs probably checked the units operation,but did they get in the attic to see that the duct work on the return air side of the unit is tight and not sucking in the attic air.
Aug 05, 2009 | Heating & Cooling
My r/t air conditioner will not cool down pass 83 degrees during the hottest part of the day.
Have you checked the filters to make sure they are clean?
If they're clogged they'll prevent the unit from cooling.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Have new central h/a--installed last year. Problem--during the hottest part of the day (85+ degrees), it is about 80 inside with the air going. Windows are shut, blinds barely open in lr (closed in rest of...
somebody is full of you know what. If it can't satisfy the space the unit is not working properly or the new unit was not the some capacity. If the air handler is in the attic i would look for loose duct work pulling hot air from the attic. Do you know a neighber that has the same house/condo as you if so compare model#s ck024 the # 024 is the capacity the 024 would be a 2 ton 030 would be 2 1/2ton 12,000 btu's equals 1 ton
Jun 04, 2009 | Heating & Cooling
Goodman compressor cuts off when temp too high
I believe you have 1 of 2 problems going on here your system may be overcharged causing the compressor to cut out on a overload relay circuit internally, or it also could be tripping out a high pressure switch which could be from an overcharged system or a dirty condenser. I would have the tech come out on a 90 degree day and put the gauges on and check the pressures while it is operating under a full load.
Hope this helps you.
Please rate me
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
249 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
