Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
The engine runs and then stops after running. I wait and then it starts and runs again for about 1 minute and then stops again.
I have a old 2010 Diesel did the same. It was the fuel return line from the pump to the fuel tank. It's a short ? 10" long line.
Replaced it, now it runs for ever.
Barry
Posted on Aug 29, 2009
Hi....i'm a diesel fuel injection tech. if its diesel and has a stanadyne(roosamaster) pump on it the governor inside the pump is failing & it will stop up the return causing high pressure in the pump ...and she'll cut off the pressure goes down you can restart(until pressures up again) Get the pump Rebuilt! i sold a "new" pump last week after the guy delayed the repair. cost him 1250.00 for the new! repair is 350 to 500 thanks tim
  • 73 Answers
Hi there. See if it keeps running with the fuel tank cap loose. It should be vented. Does it stay running? If not, check fuel filter/s.
Thanks
Paul
Posted on Jul 12, 2009
2006 VW GOLF TURBO DIESEL 1.9 STARTS UP GOES 5 TO 9 MILES STALLS WAIT 5 MINUTES GO AGAIN AND STALLS
Hi. It would be useful to get a code read and some live data from a decent diagnostic tool. There are quite a few possible causes including, pressure in tank - if the fuel tank can't vent pressure then a vacuum will eventually form stopping fuel getting to the engine, this will cause it to loose power and stall. Then after a few mins the pressure will drop and the process start again, easy test is when the car stalls remove filler cap - if that's the fault there will be an audible hiss and the car will start up again.
part blocked exhaust will have same problems but will more generally cause a lack of power and acceleration.
are there other symptoms? i.e only when conering or only when pulling off or stopping, engine light on/off. Jon
Dec 18, 2014 | Cars & Trucks
My corolla 2000 suddenly stop , have to wait then start again like nothing happen,
There may be something floating around in the fuel tank that blocks the fuel sock. Stopping allows it to move gain so the engine will start again.
Jul 29, 2014 | 2000 Toyota Corolla
Engine stops running
if it was a bad gas or water in the gas the car would not start and if it does start it would run really rough it sound to me like you have an over heating problem doe s the temp gauge say its over heating just before it dies?
Oct 01, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Where is the idle located on a 1994 Jeep Grand Cherokee limited
It sounds like you do have a relay problem try switching relays around that have the same part number start with the starter relay when switching the make sure the key is off each time
Sep 04, 2012 | 1994 Jeep Grand Cherokee
516 Cdi sprinter sudden blue smoking for few minutes and after OK
somthing in the ignition is causing a weak spark--or fuel inject circuit is running to rich----------all causes improper burning---------get a computer diagnostic done
Apr 07, 2012 | Cars & Trucks
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Key stuck in ignition
Be sure its all the way in park or try neutral.Its possible that security system does not recognize the key. Is security light flashing or on steady? Shut all doors and windows,trunk,hood, turn off all accessory's,roll down drivers window, turn key off and remove for at least 1 minute, insert key into ignition, try to start leaving key to run position for 20 minutes, turn key to off,wait 15 seconds, try to start again leaving key to run, wait 20 minutes, turn key off,wait 15 seconds, try to start, again leaving key to run, wait 20 minutes, turn key off, wait 15 seconds, try to start. This should relearn key code. It may relearn after 1 learn cycle and start if system is ok. Hope this helps and that the weather is dry and warm for this procedure! This is not always a fix, but works most of the time.
Jan 25, 2009 | 2006 Chevrolet Monte Carlo
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,331 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
