Question about Vizio P2 42 in. HD-Ready Plasma Television
Power to tv but no sound or picture
Remote or buttons on the set won't work, even to shut it off. It has to be unplugged to turn off. Vizio tech support no help at all. 18 month old set, in short I'm disgusted.
  • flea49 Jul 12, 2009
    Taran, I am sorry and a little humiliated. I have a vw42lhdtv10a model. I didn't fullyread the beginning message that I attached to. I don't know if this will make any difference, but I thought I should note it to you. As a John Deere Service manager and former technician, I know how important correct information is to make a correct diagnosis, based on the information the customer provides. Again I am sorry for the poor start to this diagnosis. Brian
    President:
  • 2,777 Answers
Hello there Brian, sorry to hear about these problems you are having. Also thanks for the model number and all other great information here.
There is only one thing that could cause what you are experiencing that is easily fixed by the end user such as yourself. That would be that something is causing multiple input at the same time, most likely to the infrared port. Basically it would be something similar to a button on the remote being held down constantly. To verify this isn't the problem, take the batteries out of the remote, and take all other device remotes out of the room (could be somehow another remote is sending a signal interfering, never hurts to try to take them all out). Again shut the TV down, by unplugging if you have to.
Let it sit for a good 2 minutes, hit the buttons on the front / side of the TV to make sure all power is drained from the capacitors inside the TV.
Go ahead and plug it back in. Does it immediately turn on without you pressing anything? If so then it has some sort of signal "stuck" in the memory of the TV that is keeping it locked in a permanent on state. Go ahead and try to hold the power button down on the actual TV set for 15 seconds. If this does not power the unit off at this point then you are either having voltage problems (possible faulty power supply) or the software has been corrupted that controls the buttons on the TV. Either way you would need a technician in person to diagnose and repair. Vizio does not have the best reputation for quality products or quality support either. Not trying to be rude or anything, just being forthright.
Hopefully taking the remotes out of the picture completely and doing a hard reboot including holding down the power button to turn off will clear up the issue, if not then it will need physical repairs.
Oh yes, one more thing just came to mind, although this is very unlikely. You may want to check the voltage coming out of the wall outlet to verify that it is normal, this could also cause this issue. You may want to try it in another outlet, use an extension cord if you have to, just for testing purposes.
This should cover every possible scenario. Hope this helps!
Thanks and good luck
Tim
Posted on Jul 13, 2009
  • 10,515 Answers
No Sound and No Picture is a common problem in Vizio HDTV plasma televison. At this moment, my first check point would be Power Supply Board. Take a Voltmeter and check the continuity across Power supply board. If faulty, note down the part number and order it on online vendor. There are many online vendors like ebay and so on.
Once done, let me know the update.
Hope i helped you.
Thanks for using ' Fixya ' and Have a nice day!!
Posted on Jul 12, 2009
Why Vizio E241A1 LED TV will turn on, but no picture or sound. Is this the Power Supply Board or the Main Board?
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jul 19, 2015 | Vizio E-series E241-A1 24" LED TV...
I have a 42" Vizio
Your power supply is dead.
Power supplies can be purchased online for a couple hundred bucks, and replacement is fairly simple and requires only a screwdriver.
For those less tech-savvy, you may want to start saving for a new TV.
Jun 07, 2011 | Vizio 42 in. LCD TV
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
No Picture or Sound on Vizio 52" Plasma TV
Try to use the reset factory reset feature. Unplug the set. After unplugging press the power button for 30 seconds. Plug the set back in and turn it on.
Apr 21, 2009 | Vizio L32 32 in. LCD HDTV
Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
Only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
TV wont turn on?
this product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Dec 08, 2006 | RCA 27R410T 27" TV
Vizio P2 42 in. HD-Ready Plasma Television Logo
35 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
