Question about Lanzar (Pair) MAXP104D Max Pro Series 1200W 10" Subwoofers Car Speaker
Speaker box wont work. Its hooked correctly to the lanzar amp. Theres little action. It started when we took my speaker box out in order to have space for vacation. Put it back in n after a couple days the left speaker stopped moving... now the right isnt working. If u press a tiny bit u can feel vibrations here n there...barely. HELP
  • 78 Answers
The quickest way to tell the woofers are good or still hooked up... you need a multimeter set to ohms. test each speaker and make sure you get a reading of 2, 4 or 8 ohms. ifs its a prefab box, probably 4 ohms each but still depends on make. Make sure the speakers have good connection inside and out. Make sure amp wiring is in good condition too.
Posted on Jul 25, 2009
Just bought the 2 lanzar max 15s in they blew with in a half hour of playing them how do i exchange them
Contact where you purchased them from. If they blew with in that short of time it may be user error not hooked up correctly ,wrong impedance, gain to hi on the amp didnt break them in . this will all void any warranty.. .
Mar 06, 2016 | Lanzar Car Audio & Video
On a lanzar 535n 5 channel 3200 watt amp what is the best way to hook up 2 lanzar max 12 inch duel voice coil subwoofers
If your amp allows it hook the the sub's to the first two channels but bridge it and only run it on 2ohms so you don't blow your sub's
May 29, 2015 | Lanzar Car Audio & Video
I have a Lanzar HTG2600D amp, Iv hooked up systems for years so its not the obvious. The green light is on, everything it hooked up, the fan is running but there is no sound. I pulled the base cover off...
did you run direct to the speakers or to the rear of the radio to split factory wiring. Check to make sure that you are connected to the correct side of the wiring behind the radio. If that is correct, then check the input of the amp. Try a different source and see if you get signal. Make sure your wiring is not crimped.
I use my ipod and hook it to an 1/8" x RCA splitter and plug direct in the amp. try to isolate the amp as much as possible. 1 speaker to outputs and 1 source you know works. Then test from there.
Jan 06, 2011 | Lanzar HTG2600D Car Audio Amplifier
Subs wont work or do anything when hooked up
Check your safe light on your amp if it's green then the subs are **** but if you don't have a green light check your ground, just because it sparks when it touches dosen't mean it's a good ground so grind the paint off the bolt if need be. If all else fails get new subs, do your self a favor don't get lanzar products there horrible trust me on that one
May 11, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
Trouble hooking these speakers up.
How to connect the speakers would be the opti62 have a crossover unit on the crossover you should have 6 connections the first is the input that will come directly from your radio or amps speaker out terminals. next is the woofer connect that directly to the 6.2 driver last is the tweeter that's the little speaker that puts out all of your highs. That filter on the opti692 is a capacitor for the highs for the tweeter connect it inline with the positive which is the input labeled + the other is your negitive - make sure + - is correct if not your speakers will be out of phase and not sound right. If you need wire schematics just ask and you shall recieve.
Good Luck
Jun 10, 2009 | Lanzar OPTI692 Car Speaker
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
PROTECT LIGHT COMES ON WITH 2 SPEAKERS HOOKED UP
Go to this website page and see if any of this applies to your problem. http://www.caraudiobook.com/car_audio_amplifiers/car_audio_amplifiers.htm
Aug 11, 2007 | Lanzar HTG244 Car Audio Amplifier
My vibe 286 4000 watt lanzar amp wont stay on..
Check your speaker load. It probably should be 4 ohms per channel. Also, if you are bridging then you must double your ohms load. It may be that your old amp could tolerate a lower impedence (ohms load) than the new amp. Do this now so you don't fry your amp. Good luck.
Mar 03, 2007 | Lanzar VIBE266 Car Audio Amplifier
Lanzar (Pair) MAXP104D Max Pro Series 1200W 10" Subwoofers Car Speaker Logo
127 people viewed this question
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
