Question about Kenmore 62622 Microwave Oven
Kenmore 665.61612100 microwave oven
When I start the oven I have a new, strange sound. It sounds like something is grinding or rubbing. When I stop the oven, the sound stops. Are there belts that could be wearing out or a motor that needs to be greased? Any suggestions would be appreciated. Thanks
  • Kenmore Master
  • 9,098 Answers
No belts, no grease needed.
And thank you for posting the full model number. That really helps!
It could be the stirrer or stirrer motor. These are located behind the cover in the ceiling of the oven.
It may be the turntable is rubbing or you may have a bad turntable support or motor.
These are the most likely suspects. It will take some investigation.
If you or a friend want to look into it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://www3.sears.com (the 3 is correct)
Posted on Nov 18, 2007
Our Kenmore microwave oven recently stopped heating. The lights, turning plate and controls all work but with no cooking is occurring. The last time I attempted to heat something up I heard a cracking...
The most likely cause is a bad magnetron, "heats food" the other two possibilities are the high voltage capacitor and diode. The cost to repair will a approach a new microwave oven.
Apr 08, 2011 | Kenmore 80412 Microwave Oven
I have a Kenmore Microwave Oven.The turn table stopped rotating and the unit does not heat. It sounds like it is working but it does not heat. Does the turntable have something to do with this?
What you probably hear is the fan. If it's not heating the problem is almost certainly the magnetron. The magnetron is the main component in every microwave and can be very expensive tp replace. You'll be better off buying a new microwave. The prices on new ones have dropped dramatically, I saw a 700 watt unit selling for $50.00.
Nov 20, 2010 | Kenmore Microwave Ovens
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
I have a kenmore microwave hood combination model 721.80019. The blower unit has recently started squealing when we run the microwave. I am not sure if it is rubbing up against something or not. Is there...
I just found out the same problem with mine.
I think the bearing of the fan motor has problems.
I took it apart and now looking for a used or new fan motor unit.
Bill
Aug 14, 2010 | Kenmore Microwave Ovens
Microwave makes strange sound when turned on
The fan motor either needs maintenance including lub or it need to be replaced.
Jan 01, 2009 | Kenmore Microwave Ovens
Grinding noise from turning platter mechanism - Kenmore #63252
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 23, 2008 | Kenmore 63252 Microwave Oven
Noise on starting up
If the unit is cooking ok, then it sounds like possibly your cooling fan has the blower wheel rubbing and when the rpm's come up, the blower wheel migrates away from the rubbing surface. It is very common for a blower wheel to loosen up, or a bearing in the bottom end of the blower to fail, causing the sound.
If you dare to venture into the unknown, you can investigate the noise and maybe be able to adjust the attitude of the blower wheel or fan blade, which ever is loose
Post me if I can be of more help.
Thank you,
Dave E. (Illeagle)
Jun 08, 2008 | Maytag MMV5186A Microwave Oven
GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE JVM1650 1000 Watts Microwave Oven
Kenmore 62622 Microwave Oven Logo
277 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
