Question about LG WD-3243RHD Front Load Washer / Dryer
What is the drying temperature in the permanent press cycle?
I am new to this machine. Lots of clothes recommend a low drying temperature, but my only options seem to be automatic or no heat.
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Cloths not getting dry
id look into a clogged and or kinked exhaust vent. perhaps where it leaves the home theres a screen over the housing thats clogged itself w/lint. its generating heat, thats good now just needs to release it somehow
Posted on Mar 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: my clothes are hot, but still wet.
Them dryers are notorious for having a plastic blower wheel which gets loose and won't allow for correct air flow. here are some repair photos: HERE
Posted on Jan 04, 2010
SOURCE: I just had the LG
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Posted on Jan 03, 2011
MNTECH
  • 1543 Answers
SOURCE: I am having 2 issues. Most importantly, my front
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
Posted on Mar 03, 2011
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shield™ Plus Feature is preset to on during the permanent press cycle.
Jan 30, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
I don't know how to use my whirlpool dryer
Add clothes, close door securely, make sure it latches, select a cycle (timed dry, permanent press, etc.) select a heat setting ( low heat, high heat, or air) a push the start button. You will also want to make sure the lint filter is cleaned between each load. The lint filter will be either on the top of the machine under a little door or inside the machine at the bottom of the front.
Nov 22, 2009 | Whirlpool Dryers
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Dryer shuts off before the finish of the cycle. Clothes are not all the way dry.
If the dryer is on a timed-cycle dry, and the heat is too low and/or the air supply is restricted, the machine will shut off before everything is dry. If running on auto-sense dry, the exit air temperature sensor is shutting the machine off too soon or the air passing through the clothes is restricted somewhere and therefore getting too hot which shuts the machine off too soon. The primary suspect for air flow restriction is lint accumulation in the vents and/or the lint trap is plugged with fabric softener deposits--wash it in detergent and hot water. Hope this helps.
Aug 28, 2009 | Dryers
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
LG WD-3243RHD Front Load Washer / Dryer Logo
148 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
