Question about Whirlpool Dryers
What do you do if the silver coil behind the dryer comes disconnected
  • 24 Answers
I'm assuming you're referring to the exhaust hose. If it's an electric dryer, just unplug it and pull the dryer away from the wall and reattach the exhaust hose using the the hose clamp. Make sure it's good and tight before you place it back into position. Plug it in and you're good to go.
If it's a gas dryer, you need to be much more careful. I'd recommend having a qualified tech or handyman do this. You don't want a gas leak. They will know the proper steps involved in disconnecting and reconnecting the gas line so the exhaust hose can be reattached.
Posted on Jul 12, 2009
GE Dryer runs but no heat
What is the model number of your unit?
Oct 31, 2012 | Dryers
We have had problems with our dryer not atarting. The repairman has come to our house 2 times. The first time, he said that it was a heat sensor switch that needed to be replaced, so he replaced it. It...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Roper Dryers
MDG6200 dryer doesn't dry and clothes aren't warm after cycle. I took off front cover and observed that flame comes on, but then cuts out a minute or two after starting. Airflow/venting not problem, since...
The gas valve is shutting off too soon due to a weak solenoid coil that shuts off when it gets hot. Replace the solenoid coils to address the problem. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Unplug the wiring harnesses from the solenoid coils then remove the two screws securing the coils holding bracket. Remove the bracket and lift the solenoid coils off then replace it in reverse of the removal steps.
May 29, 2010 | Dryers
I have a Kenmore Elite gas dryer the gas will
Just replace the two solinoid coils on top of the gas valve,unplug the dryer always! Two phillips head screws hold the half bracket over the coils. The larger three wire coil may have a silver sleeve in it, you need to reuse that. Just replace the set and reassemble it, your done.
Aug 30, 2009 | Kenmore Elite 45986 Front Load Washer
No heat
check your heating coils they are located behind the back cover
right hand side (if you are faceing it)
on my kitchenaid (behind the back cover) their is a long silver looking box with a small hole in the top look in the hole and you should see the coils (just remove the cover to get to them)
Jan 24, 2009 | Kenmore 62602 Electric Dryer
Need to know where heaqting element is on Model FDE546LESO
Depending on your make. There are 2 places the manufacture puts heating elements.
1. The back panel of your dryer will come off. and it will be a long silver metal shell on the left side of the dryer.
2. The top of your dryer will come off and behind the drum there will be a large circular metal casing. it will about the size of the drum of the dryer.
Let me know if you need any more assistance with this problem.
Happy Holiday's
Dec 10, 2008 | Dryers
I'm moving and am taking my Maytag Atlantis W & D with me. The moving company said I need to disconnect the gas lines or they won't move it. How do I do that? Is the metal coil that appears to be the...
the dryer does not have any gas lines those are all part of your installation, there should be a shut off valve for the gas supply behind the dryer itself,YOU NEED TO TURN OFF the gas supply to the unit before disconnecting. the moving company wont do it for the liablity of blowing up your house! if you dont feel comfortable disconnecting a gas line or are uncertain of gas being off to the unit I STRONGLY reccomend that you have a qualified person disconnect your appliance.
Oct 25, 2008 | Maytag Dryers
Magic Chef YE228LV Dryer schematic
dryers only have 1 heating coil and it is located on the back inside panel of the dryer. Before you go taking you dryer's heating coil out please check the temp relay. now some dryers have 2 of thoses they will be on the heating coil case and look like silver button and usually have 1 or 2 wires on it. If the dryer will not dry as well as it use to than what may be happening is that the relay my not be working properly and telling the heating coil to only come on for a short time and than shut off again. now the relay's are the cheapest thing to fix. i would start with thoses. if that does not work or ou need more help please contact me again and i will assist you with disasembling you dryer to get to the heating coil.....
Jul 31, 2008 | Magic Chef Dryers
Dryer not drying
be sure vent to outside is not blocked or hose behind dryer flattened..quick ck is to dry a load with rear hose disconnected..if problem still there suspect heating element ..ge/hotpoint elements are double strung if 1 coil is open (burnt into) dryer will not get hot eneough
May 19, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Open Questions:
Dryers Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
