GE Slim Spacemaker 7-5295 CD Shelf System Logo
Can't set. Where can I get a manual? - GE Slim Spacemaker 7-5295 CD Shelf System
1helpful
Nissan x trail set time clock
https://www.nissan.co.il/content/dam/Nissan/israel/services/car-books/Nissan-Xtrail-Car-Book-2016-ENG.pdf
Page 4-5
Clock:
Select the corresponding keys to adjust the settings.
• Time Format:
The time setting can be selected from 12 hour
and 24 hour formats.
• Date Format:
The day, month and year display can be selected
from five formats.
• Clock Mode:
Select the clock mode from Manual, Time Zone
and Auto.
When [Manual] is selected, you can set the clock
mode manually from the [SET CLOCK MANUALLY] screen.
Select [Auto] to automatically maintain the time
using GPS.
• Set Clock Manually:
Mode (AM/PM) (where fitted), Hours, Minutes,
Day, Month and Year can be set manually if
[Manual] is selected in the Clock Mode setting.
• Daylight Savings Time:
Turns the daylight savings time on or off.
• Time Zone:
Select the applicable time zone from the list.
1helpful
Ineed a manual to set tv, add cable box and vcr
images for manual to set tv
PDF]Apple TV Setup Guide (Manual)
https://manuals.info.apple.com/MANUALS/.../AppleTV_Setup...
Apple Inc.Contents. 1. Connect. 2. Configure. 7 What's in the Box. 8 What You Need. 10 Apple TVat a Glance. 12 Setting Up Apple TV. 18 Network Configuration.
[PDF]USER MANUAL - VIZIO
1helpful
I have an ACURITE 00590A1-RX. My time is off by 10 minutes. i don't have my manual and would like to know how to reset it. If possible, tell me how to download a manual.
From the manual, such as it is:
Set the Time Manually:
If you want to set your alarm clock a little ahead or if the unit ever loses time for any reason, the time can be set manually by following these steps.
1) Press and hold the "CH./SET" button for seven seconds to begin the manual time set mode. (2 BEEPS) The hour will flash on and off.
2) Adjust each setting by pressing the "+" or "-" buttons. Confirm and move on to the next setting by pressing the "CH./SET" button.
MANUAL TIME ADJUST SEQUENCE: hour, minute, year, month, date
This works for me. You have to be sure to keep pressing the CH/SET button for the full seven seconds -- the first beep the the clock gives you will only allow you to set the time zone and DST function.
2helpful
3answers
Poulan pro bvm200vs, what is the spark plug gap suppossed to be set at?????????????
re: "The plug should be set from the factory check your manual for the gapicon1.png setting"
Chris, If people had the manual do you honestly think they would waste their time looking for the answer online.
Chris - I hope you don't get paid for offering 'Check your manual' answers.
1helpful
Bios settings
?manual? when you go into your BIOS at the bottom of all generic BOIS consoles, there are F1 - F12 options. one of these will be: restore to failsafe settings" and the other "optimized settings" the rest you can tweak manually. as far as a manual goes you must be referring to the motherboards manual, and it only touches on BIOS and CMOS settings. good luck.
Top GE Audio Players & Recorders Experts
Rob Hill
Rob Hill
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
