Question about Electronics - Others
Dual Brite sensor lighting. Lights will not stay on even after human motion is in place sight of sensor during evening hours. I have the switches on dusk to dawn and the on-time switch is set to 20 minutes. Why does the light keep shutting off if it's set to dusk to dawn
  • 3 Answers
I really don't understand why these lights are so failure prone and I usually return at least 8 out of 10 back to the store but I've installed a lot of them. If its Zenith brand the light may need to be reset by turning the power off at the switch or breaker for 1-2 min then back on. Then check the motion sensitivity dial if its maxed out turn it back and set it to 75% full also the photo eye may be getting light from the light making it think its daytime at night so try to reaim the photo eye if possible away from the light source that should fix most problems or 20% of them but if you still have problems return it to the store or ask for their advise. Hope this helps I've seen a lot of junk motion lights in my time they are troublesome at times.
Posted on Jul 17, 2009
  • Bob H
    Bob H Feb 22, 2014
    Check to see if any light is reflcting back on the sensor. Reflected light will cause the dawn sensor to turn off.
My Defiant LED outdoor white Blade Motion Security stays on all night
You may need to set the parameters once chosen which means you need to hold the set button in for at least three seconds once you have selected your choices.i usually set new up in the house and then check the duration of the light before installing in situ.
Jan 28, 2015 | OUTDOOR Home Security
I have set all the switches to the left TEST, Low sensitivity and Dual brite OFF and this light stays on all night??
putting the switches on test bypasses all the sensors leaving the light on all the time the test selection is only there to see if the light is working
Jan 15, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
Lights flash on and off
Very common issue with motion sensing lights. You can either replace the light sensor which is available at most hardware stores or you can disable the motion sensing feature and just have an on-off light. To disable the sensor, (turn off the power!) unscrew and remove the light sensor (it is the reposition-able box under the light.) It depends on the particular light, but you usually just match up the wire coming into the light from the house and the wire from the bulbs and connect them with a wire-nut.
Jan 07, 2014 | Heath Zenith SL-5318-WH Dual Brite Motion...
Lights flash on/off non-stop, until reset, then does it again. model SL-5408 GR-B
Have you reset the controls on the sensor itself. Suggest you reinstate factory settings and start over.
Hope this helps.
Aug 31, 2013 | Heath Zenith SL-5318-WH Dual Brite Motion...
Light does not turn off in daylight
When photo cell lights do not turn off during the day, this is more often than not an issue with the detector and or the relay module. Try climbing on a ladder and check if the lights module can be accessed with a small screw driver or pried open with a flathead tweeker. If you have a digital multimeter, look for where the module gets it power from. Normally the module is DC voltage, but depending on the manufacturer, nothing is normal. Also check for debris and the exterior lens (where the light strikes the sensor) is not weathered so back that it deflecting light. If it is dark, light cannot enter the sensor thus not allowing the unit to shut off.
Hope This Helps!
May 24, 2013 | Heath Zenith SL-5318-WH Dual Brite Motion...
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
Jul 06, 2012 | Heath Zenith Secure Home Motion Activated...
Cannot get light to go on and then off at programmed time. Stays on. At cottage with no neighbours or ambient light. Installed professionally, not by myself. Frustrated many efforts before contacting...
Light stays on all the time: Turn power to light off. Wait 10 seconds. Turn power back on.
Typical option on motion lights: Quick power flick -- light stays on. Slow power flick -- light goes into motion sensing mode.
Hopefully the professional installer gave you a switch.
Jun 01, 2011 | Heath Zenith SL-5318-WH Dual Brite Motion...
My journeyman motion light just quit working for no reason. The bubls are good. As mention it was working fine then just stop working. What could be the problem?
The motion sensor unit shorted to due to rainwater infiltration, if its like the last half-dozen motion sensor units I opened up. Take the unit down, open up the sensor unit head, and if its got moisture inside, you know why it quit. If not moisture, then they sometimes do what all electronic devices eventually do, they fail due to 1 of the components reaching its failure - every sensor has an MTBF
(mean time between failure).
Jan 05, 2011 | Heath Zenith Journeyman 270 Degree Motion...
I would like to rewire a solar security light (motion activated) to stay on at dark. Brand westinghouse
The light will only stay on as long as the battery lasts. My guess is that will not last all night. What you can do is buy a light sensor switch (or even a light sensor socket adaptor is available to save you from having to wire it in) to keep a light on during the night. You can use a CFL or even an LED lamp to save electricity, but it is unlikely that a solar-charged cell will power even one of thes all night long.
Nov 16, 2009 | Solar Motion Security Light Conversion...
Flood light has faint glow at all time
Sounds like you have the Dual Brite on, the dual brite is low level accent lighting. Check to see if you have this switched on, if so turn it off.
Mar 12, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Electronics - Others Logo
917 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
