Question about GE Refrigerators
Loud vibrating sound with compressor starts up
We purchashed a HotPoint side by side refrigerator Model HHS251FMS WW in July of 2002. Now when the compressor starts up there is a loud vibrating sound that comes from right side wall of the fridge. About half way down the side.
    Champion:
  • 233 Answers
Remove the back cover and visually inspect the small fan under the fridge, chances are the fan or blade has become unbalanced or the mount has come loose or failed.
Posted on Jul 12, 2009
Right before the refrigerator starts running, the unit vibrates, makes a clicking noise, and then a series of loud banging noises that sound like hitting a ping pong ball against a table. Then it gets...
This is just a WAG but it doesn't sound like a compressor problem to me. The clicking could be the start relay, which could be a combination of either the start relay or start capacitor.
The vibration and banging is probably the shock mounts that the compressor are mounted to the cabinet frame with. Although rare, if the screws come loose the compressor will slowly destroy the rubber grommet shock mounts. If you are missing even one grommet (need four) then it will vibrate and rattle. If two screws are loose then it will allow it to vibrate and rattle also.
All bets are off if the compressor is very hot to the touch! Then it probably is the compressor.
Jul 10, 2011 | Whirlpool ED2SHAXM Side by Side...
Just moved, don't know how to hook up water supply to HOTPOINT MODEL # hss25GFPE WW
Find the water valve down by the compressor and connect your water supply, check for leaksthemobilian_52.gif
Apr 11, 2011 | Hotpoint HSS25GFP Side by Side...
Our freezer quit working tonite..hss251fmdww model # hotpoint side by side
My new years gift was for my Hotpoint HSS25IFMD to stop cooling. Lack of any cooling is typically a bad compressor. This model refrigerator was made in 2002. Seems like the compressors are designed to fail within a year or two after the warranty expires.
Dec 10, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I HAVE A wailing HOTPOINT HSS25GFPH WW refrigerator
change the rubber isolating washers on the pump and compessor too hard a compound will make things worse ,neoprene works best ......
Feb 07, 2010 | Hotpoint HSS25GFP Side by Side...
A loud vibrating sound
Bad compressor, if the compressor is going bad or the bolts that hold the compressor in place are loose. Check to make sure the bolts are tight. If not check the compressor with your hand and see how much it vibrates.
Jan 02, 2010 | Kenmore 53642 / 53644 Side by Side...
Loud vibration
If it is a frost free check the fan inside. The fans can have bearing failure after a few years thus causing the vibration. Also the compressor underneath is mounted on rubber vibration dampers and if one of these rubber mounts fail then the compressor will start vibrating against the refrigerator frame causing a loud vibration. If none of these apply gently press on the side and front panel of the refrigerator to try and locate the source of the vibration as any where metal is vibrating against metal the side and front panel act as a sounding board amplifying the sound. If you cant locate the vibration then you may have a more serious problem and may need to call a technician.
Oct 09, 2009 | Roper Refrigerators
Not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
