Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
TV won't turn on (and setup menu keeps appearing on screen)
The remote won't turn the t.v. on (but it's not a problem with the remote, because I tried it on another Sony t.v., and it worked just fine).
Also, when the t.v. IS on, every once in a while, the setup screen appears for a few seconds and disappears.
Any thoughts?
  • 149 Answers
Hi there, see any cold solder or else a system control ic is defective, check some parts, do some test. ty
Posted on Dec 29, 2007
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
How d I activate an external antenae
1. Press TV to select the TV mode.
2. Press POWER to turn on the TV. The STARTING SETUP function
begins and the language setup menu appears on the screen.
Press upArrow (^) or downArrow (v)to select your desired
language, then press ENTER.
3. Press (^) or (v) to select TV or
CABLE, then press ENTER.
4. Press (^) or (v) to select START, and
then press ENTER, which
starts the AUTO SETUP.
Note:
To cancel the setup and return to the regular TV screen, press (^)
or (v) to select CANCEL and press ENTER.
5. When the AUTO SETUP is complete, the regular TV screen
appears.
Notes:
• AUTO SETUP of channels may take 15-30 minutes to complete,
depending on your regional cable service.
• To cancel the AUTO SETUP and return to the regular TV screen,
press EXIT.
from TV manual that uses a CT885
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CEcQFjAD&url=http%3A%2F%2Fwww.hdtvsolutions.com%2Fpdf%2F50hp66_om_e.pdf&ei=_KppUvWPNqjSyAHTr4DIAg&usg=AFQjCNGar3aphbJ5yNHl9QMUJsSI6SjCTQ&bvm=bv.55123115,d.aWc
Aug 15, 2013 | Toshiba Ct885 Remote Control
Screen keeps displaying menu options when that button is not being pressed on remote have to turn off tv to get back to regular viewing or game playing what is making this screen keep appearing
Hi. I suspect that the remote may be the cause. Remove batteries from the remote and see if the menu appears. If it dosent, I suspect the remote may have had something spilt over it and needs to be cleaned out. Hope this helps you out.
Feb 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
I am trying to set up my roku with my router and I cannot find roku.com/link on the web.
Place the Roku box on your TV or entertainment center and plug it into the wall outlet. Connect the box to your TV with the included AV or HDMI cable. Insert the included batteries into the Roku remote.
  • 2 Turn on the Roku and the TV. Press the "Input" or "Source" button on the TV remote until the Roku menu appears. Follow the instructions until the wireless setup screen appears. Use the remote to select your network and input your Wi-Fi network access code, then press "next."
  • 3 Turn on your computer and log in. Start your Internet browser and type "roku.com/link" in the address bar. Press "Enter."
  • 4 Set up a Roku account if your don't already have one. Enter the code that appears on your TV screen to finish the setup process.
  • Read more: How to Set Up Roku Wireless ' eHow.com http://www.ehow.com/how_7459834_set-up-roku-wireless.html#ixzz1AZ8NBDhQ
    Jan 09, 2011 | Computers & Internet
    Can't seem to switch to input with the remote or go to any channel to use my DVD player
    Hello
    Check first if the Remote Control hanset emits infrared rays or not. Infrared rays are invisioblw to us. There is an easy way to check it. if you have a cellphone with camera option, set it to camera mode, and place the remote hanset against its lens about 1 feet away or so, and press each button on the remote control. You can see the infrared indication on the screen of your cellphone.
    If it is Ok, just reset the remote control.
    You might need to reset the remote: remove batteries and press the number 1 button for at least 60
    seconds. Release the 1 button, replace the batteries, and (if necessary) program the remote again.
    Check also for
    Something might be between the remote and the remote sensor on the component. Make sure there is a
    clear path.
    • Maybe the remote isn't aimed directly at the component (DVD, TV, VCR) that you're trying to operate.
    • Maybe remote is not in TV Mode. Press the TV button so remote will control TV.
    • Maybe batteries in remote are weak, dead, or installed incorrectly. Put new batteries in the remote. (Note,
    if you remove the batteries, you may have to reprogram the remote to operate other components.)
    How to Use the Remote Control to Complete
    the Initial Setup
    The technical term is "Navigation"- how you move through the
    on-screen menus. The method is the same throughout the menu
    screens: highlight your choice and select it.
    To highlight a menu item, press the arrow buttons on the remote
    to highlight one of the items listed on the screen. Use the up or
    down arrow button to move up or down. Use the right or left
    arrow button to move right or left.
    To select the item that you've highlighted, press OK.
    Note: Highlighted means that the menu item stands out from other
    menu items on the list (appears darker, brighter, or a different color).
    Turn on the TV
    Press TV on the remote, or press POWER on the TV's front panel.
    Note: Pressing the TV button not only turns on the TV, but puts the remote
    into TV mode. "TV mode" means that the buttons on the remote control
    operate the TV's functions.
    Complete the Initial Setup
    The menu system in your TV allows the TV's features to work
    properly. The first time you turn on your TV, the SETUP screen
    appears with Language highlighted. The default language is
    English. To choose another language, press the right arrow
    button on the remote.
    If these doesn't work, the infrared sensor inside your Tv has got damaged and should be replaced. OK.
    Nov 29, 2010 | RCA 27R410T 27" TV
    How do I enable closed captioning on my Zenith PIP System 3? Thanks.
    Hello
    To enable close cationing on your TV follow this:-
    [1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
    [2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
    [3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
    [4] Press enter to return TV viewing.
    To turn the caption feature to "On" or "Off'
    [1] Press menu key on the remote control to display "Setup" menu.
    [2] Using "UP/DOWN" buttons to select captions on your screen.
    [3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
    [4] Press enter to continue.
    Ok.
    Oct 22, 2010 | Zenith C27A24T 27" TV
    We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
    Hello
    Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
    [1] Press power button on the front panel of your tv. The initial setup screen appears.
    [2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
    The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
    To perform autoprogram again
    [1] Press Menu button.
    [2] Press to highlight Channel Menu
    [3] Press Pr Dn button to hilight cable. Press [+] to select.
    [4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
    [5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
    [6] After autoprogram finishes, press "Menu" again to exit.
    TO RESET THE TV TO FACTORY SETTINGS
    [1] Turn TV on.
    [2] Press and keep hold the "Reset' button on the remote control hanset.
    [3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
    [4] Release "Reset Button" now from your hanset.
    These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
    Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Can't get the Guide Plus screen to go away
    Try these options
    Option A:
    Select the GUIDE Plus+™ Menu from the Main menu.
    Select Setup.
    Select Options.
    Select Off.
    Option B:
    Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
    Select Off.
    Option C:
    Press GUIDE on your remote control.
    Select the Menu bar.
    Press the right arrow button to select Setup.
    Choose Review Options.
    Select Off.
    May 16, 2008 | RCA F27649 27" TV
    A problem with the television
    Just guessing but the menu button the remote may be sticking Try turning the remote away from the TV. Also the menu tact switch inside the set may be defective
    Mar 16, 2008 | Zenith SY2768S TV
    "ch set" appearing on screen
    Need to get into the menu pages to setup the tuner. Just buy a under $10 universal remote but make sure it has a menu button.
    Or - many other products that use remotes often have an option for programing it to work with other equipment.
    Dec 30, 2007 | Emerson TS1997 19" TV
    Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
