Question about Hitachi C29-F300B 29 in. Television
Where can i get an adapter to hook my cable up to the television
  • 36 Answers
Walmart fredmyers radio shack
Posted on Jul 12, 2009
How do I hook up my phone to tv
What type of phone?
IPhone? To do that with an IPhone you will need airplay and apple TV.
second solution is to buy an HDMI cable adapter for IPhone APPLe component AV cable.
Samsung Android? To do that you will need an All Share Cast Wirelles Hub.
Second solution an MHL adapter cable.
Dec 05, 2014 | Televison & Video
Advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
Aug 07, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have the TV above and the cable man came out to hook-up to cable TV and couldn't figure out how to get the cable box to work on the TV turner. He had to hook it up to the auxiliary jacks on the back of...
is there a coaxial cable jack in the back of tv..(if not you may need an adapter..hook to antenna)..then set the tv to ch 3 and set to cable broadcast not air. then you will use the cable box to tune to ch.
Jun 03, 2010 | RCA F20645 TV
How do you hook up regular coax cable to the TV?
You simply need an "F" connector to "Belling-Lee" converter. about $4.00. At any Radio Shack, Antenna shop. This screw onto the end of the existing antenna connection & makes it so you can plug it into the Socket at back of set.
I have included a link that has a picture.
http://cgi.ebay.com/1-Coax-TV-Adapter-Connector-PAL-Male-to-F-Female_W0QQitemZ110386773163QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item19b3907cab#ht_683wt_1139
Feb 16, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Do not know why there is no way to hook up a DVD player.
most stores sell both adapters needed to hook up dvd or any type of electronic equipment buy a a/b switch so u can switch from dvd to [cable or satellite] then buy coaxle adapter which has 3 wire hook up to coaxle for tv [rca $10 ] and coaxle wire. connection wire a or b from dvd to adapter and other from a or b to cable/satellite other end of a/ b goes to tv slide switch to watch dvd and slide back for reg tv
Oct 11, 2009 | Toshiba CF19G22 19" TV
Using a vga cable to hook up my pc to the tv and doesnt work
did you change the imput --use the remote--push imput, change to component
Mar 12, 2009 | Olevia LT37HVS 37 in. LCD HDTV
How to hook up a sound system
Go to Radio Shack. Find the phono adapter and cable section of the store. The adapter you want has a one eighth inch male plug on one end, and a set of female phono plugs on the other. Insert the male end of the adapter into the stereo headphone jack on the side of your television. Run a set of phono cables from the adapter to your receiver. Turn the volume of your television up to the maximum (100.) You should be able to switch between the different surround settings in your menu.
Jan 06, 2009 | Polaroid FLM-4234BH 42 in. LCD HDTV
Problems with Nintendo Wii 480p component cable
Try hooking it up with whatever cable it came with. We have this same t.v. and also have our Wii hooked up to it and have no problems whatsoever.
Feb 05, 2008 | Hitachi 53UWX10B 53" Rear Projection...
I cant find a aux on my tv to hook up the dvd.
I am guessing that your game is hooked to the cable connector on the back of the tv and is switched. Do you know you can get a special adapter that uses the rca jacks (white,red,yellow) out of the dvd to the adapter and then out of the adapter with coax to the cable connector on the tv where the signal goes. I think you can get them at WalMart or Radio Shack. Upgraded tv's have the red white and yellow inputs for dvd. Hope this helps.
Dec 29, 2007 | Televison & Video
Hitachi C29-F300B 29 in. Television Logo
83 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
