Question about LG Refrigerators
Side of frig is hot
Outside side of frig is hot
  • 4,059 Answers
Make sure the condenser fan underneath the unit where the compressor is is running. If that's not it check for ice buildup behind the back wall inside the freezer .(defrost problem)
Posted on Jul 12, 2009
Water pools at the bottom on the inside the freezer side of a side by side frigidaire. This frig has a water line for automated ice and dispenses water/ice on the outside. At the bottom there is a vent...
your defrost drain is plugged remove the back panel in side the freezer at the bottom you will see a metal pan with a hole in it clean around the whole and flush it with hot water a turkey baster works great for forcing hot water thru the drain and clearing what ever is plugging it
Mar 07, 2010 | Refrigerators
My Whirpool frig is almost too hot to touch on the outside of the side of the freezer. About an 8 inch strip on front edge. Any suggestions?
When the refrigerator is on, check at the bottom of the fridge to see if there is any air blowing out. If not, your condenser fan is not working and this will cause the condenser to be very hot and transfer heat around the outside of the freezer door. If the fan is working, try cleaning the coils. Although my guess is the condenser is running hot for some reason.
Jul 04, 2009 | Refrigerators
Half-way up on the outside of the frig. gets hot also get some water in dump pan on bottom ? any suggestions?
heat in the cabinet is normal due to a conds. cooling loop inside of the cabinet, excessive heat is due to a condenser clogged with dirt or a broken condenser fan, replace or clean as needed.
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire #FRS24XHA is hot to touch and freezes food on the left
Hi: Those areas are designed to be warm to keep moisture from forming there(Moulion coil). When they get hot it means the fridge is over working. The condenser coils remove the heat from the fridge. When clogged the heat will leave anywhere it can. The moulion coil is the strip you described,and will overheat when the condenser coils wont disperse the heat. Most likely the coils need a good cleaning, on the bottom of the ref. Use a coil brush and a vacuum. Or even an air compressor to blow the dust and hair out; plan on dusting the house too. Pull the grill off the front and clean them. If real bad pull the panel of the lower back and clean it out too. Since you work in detroit the dust and hair on the coils would be like putting a blanket over your radiator. Parts would heat up. I hope it's just the coils. If a compressor is failing you can get the same symptoms. I hope it is the latter for you, as I'm in your boat also. I hope this helps, Jeff
Jun 09, 2009 | Frigidaire Refrigerators
GE GSS20IEPAWW Freezer Not cold outside of freezer very HOT
check to make sure that the fan in the back is working and then clean the condenser coil underneith the frig
Apr 26, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Outside wall on freezer side is hot to the touch
clean your condenser coils under the frig,your over working with dirty coils and it is over heating-mike
Oct 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
87 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
