Question about Panasonic PT-53WX52 53" Rear Projection Television
The PT-53WX52 When I turn on the PT-53WX52 it turns off after 10 seconds. Then the red light blinks three times waits 8 second and repeats another series of three blinks. The cycle of the lights blinking repeats it self until you unplug the TV. Help what is the problem?
  • 1,139 Answers
Re: The PT-53WX52
This looks like a problemcausing the shutdown circuit to trigger. The shutdown circuit prevents the TV from being further damaged by an overcurrent or overvoltage event. The overcurent event is caused by a component being over driven and thus it decreases in resistive value causing an increase in current, The over voltage event is caused by a component increasing in its resistive value either due to an open circuit or decrease in the component's conductive area. In any event the shutdown circuits senses these eventes and shuts the TV down to prevent futher damage.
I would suggest taking the set to your local TV repair shop.
I hope this helps,
Posted on Nov 16, 2007
0 characters
3 Points
TV turns itself off after being on a few seconds, ...
Three time blink means tv got problem in convergence output circuit, replace convergence output ICs to solve the issue.
May 21, 2010 | Panasonic PT-53WX54 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
PT53WX42F, power light blikns 5 times every 8-10 seconds, tv does not come on
Blown convergence amplifier chips. Very common and expensive repair unless you do it yourself.
Jun 04, 2009 | Panasonic PT-53WX52 53" Rear Projection...
My Panasonic PT-53WX52 rear proj. TV won't turn on?????????
from what I have found out their is a problem with the power unit inside the television. Could be a convergence chip that shorted out
Nov 20, 2008 | Panasonic PT-53WX52 53" Rear Projection...
I'm having a problem with my Panasonic PT-53wx52
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from
Oct 30, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Sudden shutdown - Red light blinking 3 times
Replace both convergence Ic's Stk392-110 and personally I'd use STK392-150's for greater reliability. Also check all 2.2 ohm 2w resistors for open or change in value and replace as many as needed...
Apr 18, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-53WX52F rear projection powers off after 10 seconds
I had the same problem and found the answer at Then I found a detailed write-up for the procedure at that gave me the courage to attempt the repair.
The result was successful. The TV works and the picture looks better than ever. It cost me about $40 in parts and two hours of labor !!
Dec 15, 2007 | Projection Televisions
Panasonic PT-53WX52 53" Rear Projection Television Logo
165 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
