Question about Sony Handycam DCR-SR200 Camcorder
Scrolling screen and dark LCD screen
I have the exact problem of LCD screen as you described.
  • 125 Answers
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Meggita
Posted on Sep 25, 2009
How to fix my Benq Monitor which is scrolling full screens of different colours.
all modern LCDs have ONE and ONE only native screen size. since you did not tell us the model number we have to tell you maybe you are setting the wrong size. if the monitor has worked before then you are sending it the wrong signal.
Jul 25, 2016 | BenQ FP91V (Silver, Black) 19 inch LCD...
What is the black cloud
a BLACK cloud if covers the entire screen and even looks like motion swirling but very dark screen could be a bad board OR may be the front display Panel.
On PLASMA SETS IT IS A PLASMA DISPLAY PANEL(pdp) OR on LCD sets Ldp ----in either case it is a sealed unit with an inert gas inside--if the panel ruptures inside you will have exactly what you describe.
Sometimes there is a defect in making this unit--sometimes if set is transported even a mild jolt will do this.
Bottom line is if the display panel is bad--fatal from a cost view as the part alone will cost more than the set itself.
May 06, 2012 | Samsung LN-R460D 46 in. LCD Television
Dark screen
Aparently the problem you are describing is caused by the baklight of the LCD screen.
This link contais a video that explains how to replace this part:
http://www.desmontalo.com/?p=275
Apr 29, 2012 | Sony Cybershot DSC-T200 Digital Camera
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 06, 2011 | Computers & Internet
Random faint horizontal lines scrolling down screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 25, 2017 | LG 50PS60 50 in. Plasma HDTV
Disply screen is dark
Hi
Thank you for your query
The problem you are describing is related to your inverter board
The inverter board is responsible for ramping up the power from 12v to 240V to allow the LCD screen to light up
Please can you book the laptop in at a reputable PC shop for a inverter replacement
Mar 03, 2010 | HP Pavilion dv6000z Notebook
Dark bands scrolling down the screen
It can be bad filter caps are bad, look inside for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
It can damage more circuits if you keep on using the monitor.
Feb 22, 2010 | Acer AL1717 17" LCD Monitor
My screen went dark suddenly, when I try to restart my computer the screen is tinted red before going dark again. The screen is not completely black as there is letter visible underneath.
From what you are describing, it sounds like the inverter board is failing. This board sits under the LCD screen and is responsible for taking the DC voltage from the battery and AC adapter and converting that voltage to high voltage AC power for the backlight lamp that sits inside the lcd screen. Without that high voltage the screen goes dark. Most inverters do not fail right away, there are voltage fall offs etc. Inverters are approx. 15-20 bucks on ebay, for most laptops, they can be changed out simply by removing the bezel around the screen, unplugging the two connectors on the inverter and changing it out. In most cases except Dell, the inverter is just sitting in there and is not held in by screws.
Nov 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
All of a sudden I have problems with the LCD Display Panel of my samsung laptop. There are think dark lines that keeps scrolling in the panel. Any suggestions
Try connecting it to an external monitor... if the problem persists on the external monitor, then you have an issue with the video card or motherboard. Try drivers first, then replace parts.
If the problem does not occur on the external monitor, then you need a new LCD screen.
Good Luck.
Sep 08, 2009 | Computers & Internet
When I turn on my calculator, every pixel on the screen is dark?
try pressing 2nd-> "up arrow" to adjust the contrast, keep doing it and it may solve ur problem
Sep 29, 2008 | Texas Instruments TI-84 Plus Calculator
Sony Handycam  DCR-SR200 Camcorder Logo
514 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
