Question about Kenmore Elite 45986 Front Load Washer
Machine will not open and displays 02f error - Kenmore Elite 45986 Front Load Washer
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I have a Kenmore Elite Smartwash QuitPak9 washer. I keep getting error messages 02F and Sud or 5ud . Seems washer will not drain , Can get it to drain sometime , no clog
its a suds sensor error. meaning tom much or the wrong detergent was used and it has clogged the wash cycle, you will have to try to run rinse cycles over and over to u clean it out if u can, some machines have an auto clean cycle for this problem, it is difficult to deal with as I have the same issue with one of mine and still not running right
Jan 07, 2017 | Kenmore Washing Machines
I have a duet front load that want run a load it say 02f what does this mean
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Sometimes the water will not drain out, of my Kenmore Elite HE3 washer and it will display 02F. The door will not open, when I press the drain/spin button it makes a funny noise, won't drain, nor will it...
Hi, You pump filter screen is clogged up of you may even actually have something stuck in the pump. Unplug machine, remove the bottom front panel 2-3 screws along the bottom. look for the filter/screen housing next to the pump. place a shallow pan under it. Be prepared for lots if water and debris. Unscrew it slowly to drain then screw it back in to shut off and dump pan repeat until no longer full of water. Remove and clean all debris out screen, housing and hose.
Nov 01, 2010 | Washing Machines
Sometimes the water will not drain out, and it will display 02F. The door will not open, when I press the drain/spin button it makes a funny noise, but sometimes it will work just fine for a couple of...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Sep 24, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
It works almost to the end until the last 2 minutes it stops then code 02f appear on the panel, can not open the washer.
Sep 19, 2010 | Kenmore Elite HE5t Washer
Sud keeps popping up on the display or 02F flashes & then it stalls.....help!
I just fixed mine. Take off the the front kick paned (3 screws), in the center inside is a handle, turn it, but be careful a ton of water comes out. Inside there is a plastic cylindr that was coated and plugged up with a bunch of smelly linty type yuk. I cleaned it out real well and it works and smells great.
Jun 30, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
02f code
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite HE3 front oading washer says 02F
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 18, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet won t spin continues to beep and
Jun 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
81 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
