Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Mower squeeking - mowing as usual, and it's squeeking, checked oil, it has oil in it, what else should I check, mower 1 year old, I've done minimal maintenance on it. and can't find my owners manual.
    Problem Solver:
  • 11 Answers
Does it squeek when at an idle, or when driving, or cutting? Does it cut fine? I would check the belts and pulleys and blades for extra play. I had a mandrel bearing go bad on my ys4500 (also about a year old) and the first symptom was a squeeling sound when the blades were enguaged. Play in the mandrel caused the belt to squeek at the pulley that turns the blade. It also cut some nice gouges in my yard due to a floppy blade. I hope that this helps, I got the answers to my problem here on fixya.com.
I believe that one can find a downloadable .pdf version of the owners manual with a quick google search.
good luck
Posted on Jul 28, 2009
Brakes seem to be draging mows really slow
Please raise the machine so you can work under it and examine the brakes.
Brakes often can stick from rust, dirt, vegetation from mowing, etc.
It might be you need to do a good cleaning, oiling, and adjusting of your mechanisms.
God bless your efforts.
May 05, 2016 | Garden
Briggs and Stratton needs primed to start when hot
sounds like the carby needs another clean out and did you blowout fuel tank and make sure you put fresh fuel in it not stuff that has been in your tin for more than a month
Feb 14, 2013 | Garden
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
One year old bolens push mower, 550 series B&S
How is your compression? If it is low, your piston rings and/or the cylinder walls could be damaged and pulling oil up to the combustion chamber, which will burn oil and foul the plug. If you overfill the oil you could possibly get this also. When was the last time that you changed the oil and/or put oil in it? Do you currently have proper oil level?
Sep 06, 2011 | Briggs & Stratton Garden
After finishing mowing my lawn the other day, my mower leaked (dripped) gas from beneath the bottom of the carberator. What should I do to get the leaked stopped?
Ok, first thing you need to do is check your oil. Make sure no gas has gotten into the oil. if it has then be sure to drain it.
carberators today are really having problems with very tiny dirt particles making them malfunction. after cleaning my carb 3 times in one year and having to change the oil each time, i decided to get a 6 dollar fuel shut off valve. i cut the fuel line and installed the valve. when done mowing i turn the valve off and have not had a problem since. in fact i have put a valve on all my small engine equipment.
Apr 29, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Aug 21, 2009 | Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
111 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
