Question about Frigidaire Dryers
Not heating dryer is not heating will give cold air no hot air
    President:
  • Frigidaire Master
  • 1,922 Answers
Check for 120/240volts at unit/then if you have that you can remove element and chk continuity of element,also the neutral wire that goes to the element burns off and you need the neutral to make the element operate
Posted on Jul 26, 2009
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
How do I put a heating element in a dryer?
there are a few differant styles, give me your model number and i will see which one you have.
why do you think it needs an element? if its not getting hot you may have a cheaper and quicker repair than an element
Dec 10, 2009 | Whirlpool LER4634J Electric Dryer
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Dryer not releasing hot air
if its an all electric dryer then you may have an open heating coil or a bad contact on the timer that supplies power to the heating element .. a few dryers have a fuse that could be blown ..
if you have a gas dryer then you may have a bad solonoid that operates the gas valve .. or more likely a bad igniter .. thats a module that heats up or sparks to ignite the gas .. the igniter is a replacable item mounted near the gas flame. . the heated type fail frequently on some dryers ..
Aug 18, 2009 | Dryers
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Dryer working but not blowing hot air
it sound like the heating element. look to see if it is broken
May 08, 2009 | Bosch Dryers
There is only cold air in my kenmore elect dryer
The motor runs on 120VAC. The heating element requires 208/240VAC. Cycle the dryer circuit breaker. Other than a simple issue like that, the problem could be a bad heating element, thermostat, high limit control, thermal fuse, motor centrifugal switch, timer or electronic control. It can also be a wiring issue.
Apr 27, 2009 | Kenmore 62602 Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
63 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
