Samsung HT-X40 System Logo
Posted on Jul 12, 2009
What is the code for the remote?
What is the code for the remote so that I can program my cable remote to control the HT-X40?
Anonymous
Level 1:
  • Contributor 49 Answers
  • Posted on Jul 12, 2009
Anonymous
Contributor
Level 1:
Answers
49
Questions
0
Helped
28150
Points
87
The default codes for things like that are usually the same for all products depending on the length of the code
for e.g if it was 5 digits long try;
12345.....or 00000
3helpful
2answers
How to get my Sony HT-CT60 Sound Bar Home Theater programmed to my GCI Cable remote?
This worked for me, but I have a Comcast Motorola DVD-R:
These are the codes for your SONY SA-CT60 Audio Device. Follow the instructions below to program your remote.
silver_with_red_ok_button-lg.gif Most likely code: 30158
Others to try: 31758, 31759
To program your Comcast remote:
  1. Turn on the TV or other device that you would like to program.
  2. Press the TV button on your remote control.
    NOTE: If you would like to program your remote control to work with a DVD Player, VCR or Audio device press the AUX button.
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the first code for your device listed above. If you perform this procedure correctly, the red light will blink twice.
    NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
  5. Aim the remote control at your device and press Power once (press the Play key for devices that don't have a POWER button). If the TV turns off, make sure that the VOL+/- and Mute buttons also work. If so, you're all set!
  6. If not, repeat these steps using the next manufacturer's code (you may need to try several codes to find the one that works).
1helpful
I need replacement speakers for my ht-x40
Hello
If you want to buy its original remote control, contact the authorised service center for Samaung at your town.
1helpful
Trying to reprogram my samsung home theater remote Model# HT-X40
Hi, if your remote is not function please replace the battery first. If fails, check the IR light of remote for malfunction
1helpful
Insignia Remote Code Needed for Samsung HT-X40
Many remote control codes can be found at InsigniaProducts.com. Search for your Insignia product model number and click on the Support tab.
Program a Comcast Custom DVR 3 remote for Samsung HT-X40 system
What is the color of the Select/OK button on your Comcast remote: is it red or grey?
Help
has to be in digital cable going in and the dvd has to be dolbit dts avb sound track ok to enables itself
3helpful
HT-X40 Configure to play DVD's in 1080i?
you have to be in stop mode i.e. in dvd/cd mode but stopped.you hold down the SD/HD button which is in the lower left area of the remote.after a few seconds the screen will go blank and then come back on and say 720p and you repeat the process and it'll say 1080i.hope that helps
4answers
Loss of Picture
switch from 1080i to either 420p or 720p (720p is actually better)
there is also a downloadable program from samsung.com
search for ht-x40 downloads
8. home theater HT-X40T/XAA Firmware
this will upgrade the dvd player
6answers
Dvd multiregion unlock code
use the procedure for unlocking the Samsung HT-DM150 .
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
