Question about Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW100W spins up but then stops
My AW1000W tries tto spin up to speed but just stops!
I have replaced the drain pump (Thought it may be thinking there was water still in the drum!) This hasn't helped!
I have checked the pressure switch and it seems to be functioning ok but if I leave it disconnected ie ambient pressure still doesn't work.
Have removed the 'soap ball' just in case this was blocking the draining cycle.
I Have checked the brushes to the motor and these are fine, although they do spark a bit when the motor is running.
I have checked the rpm sensor and it does give out a voltage as the motor spins (Dont know what voltage it is supposed to give out but at least there is something there!!)
Am at a bit of a loss now - the washer still leaves the clothes soaking wet at the end!!
Any help gratefully recieved - I am sure this should be an easy fix but it has got me baffled!!!!!
Thanks.
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I have a Tricity Bendix AW1000W. The drum will not
Could be anything , from a loose connection or broken wire to a control board or timer fault..You say the brushes are o/k, but if they are less than 3 or 4mm long, they need replacing.
Even the motor itself could be faulty.
I assume the drive belt is o/k, and correctly tensioned..
It is difficult to advise you further because thier are too many variables involved.
Please leave your comments on my suggested solution.
Thankyou.
Posted on Nov 25, 2009
  • 174 Answers
SOURCE: Will a Tricity Bendix AW1000W Washing Machine run
hi your machine will remember prog if there a power cut and restart from where it was interupted. So if you load the machine and start it then turn the power off on the timer it will continue when the timer switches back on (yes is the answer)
Posted on Nov 20, 2010
Washing machine gets stuck each time on Rinse, Drain or Spin cylce and can't open door!
the drain pump cant get the water out of the machine check it and also check the filter maybe something stuck in it
Feb 10, 2014 | Tricity Bendix AW1000W Front Load Washer
Why won't my tricity bendix aw1000w drain?
Check the filter and pump for coins, hair grips, screws etc and check the drain hose isn't blocked or kinked
May 09, 2012 | Washing Machines
Machine just will not spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 02, 2010 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
My Tricity Bendix AW1400W washing machine will wash but not drain. I was told I have a faulty pump which I immediately changed but the problem still persists. Can you help?
If you have replaced the pump check that the pump is actually working the easy way to tell is to remove the filter and shine a torch up inside put machine on spin or drain and see if the impellor on the pump is rotating if not then the problem could be in the wiring or the main programmer is faulty.
Apr 14, 2010 | Tricity Bendix AW1000W Front Load Washer
My washing machine wont empty water before spinning
Check to make sure that the drain pump is working or that the pump and/or hoses are not clogged.
Mar 12, 2010 | Tricity Bendix AW1000W Front Load Washer
I have a Tricity Bendix AW1000W. The drum will not rotate. The belt is fine, the brushes on the motor seem ok, the machine fills with water ok and the pump drains it ok but there is no drum wash rotation...
Thankyou.
Nov 25, 2009 | Tricity Bendix AW1000W Front Load Washer
Tricity bedix spin query
First of all make sure you have selected the correct spin speed if there is more than one setting.
Check and make sure prog 4 is mot a delicate wash prog, as it will spin at a lower speed if this is the case.
If it has a filter, locate it and remove to clean.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw1400w
not only check filter but when filter out check for foreign objects fouling pump impellor. (bra wires are the favourite) if pump impellor not visible, then put onto drain and listen for a low humming noise in vicinity of pump. this confirms that pump is powered but jammed. all you can do after that is to check continuity of pump and check there is power to pump when on drain - assumes you have a multimeter
May 03, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
81 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
