Question about Toshiba e-Studio161 All-In-One Laser Printer
Please answer the question
My e-studio doesn't run because it's electric broad doesn't appear. The weather is wet, i don't know what is the problem?
0 characters
1 Points
Windows driver
my Toshiba studio 281c printer operates normally while running on windows xp through my LAN. When I try to print on it while running on windows 7, it will not respond, it does appear in the printer list?
Nov 08, 2013 | Toshiba E-studio 281c Copier
I want to install toshiba e studio 166 printer but I don't have driver so please assist me how can i install on xp os.
Toshiba e-Studio 166 drivers are available Toshiba Official Support
Click 'Support & Drivers'
Choose B/W Copiers
Choose e-Studio 166
Select /
download the Full Installer
Direct Link for drivers download
Hope it helps! Good Luck! Thanks for using Fixya!
Jul 06, 2011 | Toshiba e-STUDIO166 Printer
Toshiba e studio 250 close duplex unit message
Dear, open the duplex cover, at right corner inner side of duplex cover,there is a micro switch which is not getting pressed,see weather duplex cover is completely closing,If copying is going on see the duplex cover is slightly getting open,if so press the duplex cover while copying is don, for confirmation that switch is not activated.
Mahaboob Basha.T
Mar 27, 2011 | Toshiba E-Studio167 Copier
Our 350 appears to bog down when making multiple copies. Almost like a memory issues or needs to "reboot". Our old copy repair guy had a way to clear this, running through a sequence of buttons (he is no...
If the MFP hang, u can try press "08" ON the machine, key in "690", u will see a value of "2" appear on screen, tap the OK button on screen in order to perform reformat for the HDD. aaa
Dec 28, 2009 | Toshiba e-Studio 350 Copier
Can't scan from HP Photosmart C7280 to my Mac Computer
The best way to scan documents from the scanner to your computer is to use HP Photosmart Essential. If you don`t already have it installed it can be downloaded from the HP site. Once in the program it is very simple to follow. It is basically a point and click operation.
Let me know how you make out and we can do other things if this doesn`t work for you.
Please remember to rate me.
Feb 02, 2009 | HP PSC 2410 All-In-One InkJet Printer
Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Toshiba e-Studio161 All-In-One Laser Printer Logo
16 people viewed this question
Top Toshiba Printers & Copiers Experts
Anthony Chiang
Anthony Chiang
Michel Smith
Are you a Toshiba Printer and Copier Expert? Answer questions, earn points and help others
