Question about Nokia N95 Cellular Phone
N95 8gb 9 key issue
Every time i write a text whenever i press the 9 key i go back to the front screen, any advice
  • stevebagley1 Jul 13, 2009
    hiya
    The phone hasnt gotten wet at all. everytime i press the 9 key in a text message the message cancels and when i press the end call button the number 9 comes up. its getting really annoying :-(
  • awsolutions May 11, 2010
    if you wet the phone you will need to replace the dome keypad
First of all sorry for my bad English.
I had this problem, and I solved it.
- Pressing the red key and 9 key had the same function
- The number 9 appeared on the screen
- The key of the camera corresponds to the "+" in the screen
What I did to troubleshoot:
I disassembled the unit with the proper tools.
Failure immediately disappeared after the disassembly.
Using a brush, I removed all the dust found inside.
I reassembled the phone.
The problem was resolved.
It is not at all a problem of solft or reset
This is a problem of poor contact.
You need to clean the interiors contacts , the golden tablets with adequate product. ( KF F2 contact or Jeltonet C1 ).
But be careful not in introduce liguide in oscillators / tunners. (Chrome housing / shielding).
Otherwise your phone will be good for the trash.
Good luck.
Posted on Sep 10, 2012
I HAVE THE SAME PROBLEM... CAN YOU RESOLVE IT ?
KEY 9 WORKS TOGETHER KEW END
Posted on Jan 18, 2012
    President:
  • Nokia Master
  • 762 Answers
Best what you can do is back up your stuff (pics, songs etc) and reinstall fware again using NSU.
Posted on Jul 13, 2009
Change screen font and size
This amazingly easy trick will instantly enlarge hard to see text on your screen!
Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles!
Using these tips you can read screen text comfortably!
With the press of two keys, you can enlarge the screen text without going into your settings.
Simply press and hold down the "control" key, while pressing the "plus sign" key.
Be sure to keep the "control key" depressed while you press the "plus sign" key.
Each repetition will enlarge the text.
This can make reading small text SO much easier!
To return the text back to its original size (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key.
Each repetition will decrease the text size.
also
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text sizes largest to smallest
Apr 23, 2013 | Compaq Presario CQ56-115DX Laptop
How to find error codes
press the back key twice.
press back + enter at the same time.
type 9-4-2-8 (text the word "what")
then enter
press the faults soft key.
Mar 23, 2013 | TurboChef TORNADO Electric Oven
Fix zoom level
This amazingly easy trick will instantly enlarge hard to see text on your screen! Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles! Using these tips you can read screen text comfortably! With the press of two keys, you can enlarge the screen text without going into your settings. Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier! To return the text back to its original (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text . also Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text s largest to smallest
Mar 10, 2013 | Acer Aspire 5500 5570-2609 Laptop
How do i change to font so that it will stay put it keeps going back to 12
Which programs font are you referring to ???
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles! Using these tips you can read screen text comfortably! With the press of two keys, you can enlarge the screen text without going into your settings. Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier! To return the text back to its original (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text . Hope this helps
Dec 13, 2012 | Acer Aspire 7250-bz600 Laptop
I have a tracfone, and I can't figure out how to c...
u doesn't mentioned the model..
but...there are three ways to solve it
  • try out pressing o key
  • try out pressing * key
  • if the above keys doesn't work..try this
in screen it shows whether it is in numeric ,dictionary,try out all the keys in your phone except num keys(1-9),exit,dail..
May 20, 2010 | Cell Phones
T-mobile dash text problem
You can not recover lost texts. once gone, they are gone.
Try to get credit from your provider.
To correct issue do a hard reset:
The T-Mobile Dash™ includes a button sequence which can be utilized to perform a hard reset. This method is much more difficult to do but it will perform the reset if the menu options are not available.
Note: Before attempting this procedure make sure to backup your data using ActiveSync. All unsaved data will be lost.
Hard Reset
1. Power the device off by pressing and holding the Power key.
Note: If device is unresponsive remove the battery.
2. With the phone off press and hold both soft keys (The two keys directly under the screen, used to open menus.)
3. While continuing to hold the soft keys, press and hold the Power button for 1-2 seconds.
4. Continue holding the soft keys until you see a message that starts with This operation will delete….
5. Release the soft keys.
Note: If you see the standard boot up screen load steps 2 and 3 were not performed correctly.
6. A boot splash screen will appear, followed by a black screen prompting: Press Send to restore factory defaults, Other keys to quit
7. Press the Send key.
8. When prompted to powercycle device, select Ok
Note: Once the hard reset is performed it could take up to a few minutes to completely boot back up.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 15, 2009 | T-Mobile Dash Smartphone
Sending text messages takes too long
out of curiosity,
what kind of sidekick was it?
and also, have you tried to give it a soft reset, yet? if not, then press it all keys down ( @ + 1 +0 ) without the + part.
and let me know its fixed.
if not, then you will have to force to do a master reset. (and yes, you will lose everything for a while. but, no worries, everything will come back in a fews as everything is in dangers backend sever as always, except, text parts)
here how: -press all the keys down at once ( @ 1 0) without quotes -when you see all 4 keys button come up on the screen, hold down the "R" and dont let it go until  you see the screen come on, let the "R" go and it will reboot once again. -and wait until everything come back and then try again to send yourself a text and see if its been sent sucessful.
good luck and let me know if works.
Mar 07, 2009 | T-Mobile Sidekick II
How do i set my autosignature ?
ok on cingular/at&t its not possible but there is a ghetto way of doing it go to ur quick notes and go down 4 lines then type what u would want as your autosignature then when u get done typing ur message press insert>then go to quicknotes then choose what u wanted as ur autosignature then send.
Jan 28, 2008 | Motorola Mobility RAZR V3
Screen turns dim
Hold down the Fn key and press the UP arrow key when this happens.
Aug 07, 2007 | Dell Latitude C640 Notebook
Nokia N95 Cellular Phone Logo
244 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
