The unit needs an alignment. Vibration and dropping the unit is the
number one killer of rangefinders.....After a while of using them,
(bouncing around in golf carts, cup holders, dropping them on the cart
path, or the ground) small prisms start to move inside and decrease the
units effective range.... (only able to hit a target at about 150 yards
or less) People that use these type of instruments have to realize that the laser beam is the straightest line in the history of man!!!. Alignment is crucial!!!
Alignment
is due. For all you players that think its okay to take off the
eyepiece cap.....(bad idea) This is why you see oily looking spots or
black spots in the view. Direct sunlight will be magnified and burn the
surface of the LCD. Bushnell is good about warranties but, if you take
it apart...the warranty is void!!!! So if its 2 years old or
less.....(send a copy of the proof of purchase) .send it to them. If
you have sunlight burns already...this won't effect the performance of the unit. Wait till something else is wrong.
THE COST..... $50 for alignment, $15 for LCD, $40 for newer eyepiece that helps deflect direct sunlight (will not prevent thermal burns but, protects for longer periods of time before damage happens) $15 for clean and adjusting. Bushnell's# 800.423.3537
mr tech geek Rate me if you can...or find out this is the truth!!!! Bushnell Repair Technician
Is it possible to get a parts break-down for my Bushnell Pin Seeker 1500 20-5103? When turning the...
(More)
Is it possible to get a parts break-down for my Bushnell Pin Seeker 1500 20-5103? When turning the eyepiece, it no longer "clicks" or stays in position. Looks or feels like detents are missing.
How do you clean sand out of your pin seeker? It was dropped along the cart path in an area of sand...
(More)
How do you clean sand out of your pin seeker? It was dropped along the cart path in an area of sand and sand got in the view finder. When you twist the end to open the lens, it sound really gritty. Is there any way to take it apart to clean it?
The rangefinder appears to take a reading, the cross hairs show on the LCD display, but no yardage...
(More)
The rangefinder appears to take a reading, the cross hairs show on the LCD display, but no yardage is shown.
My Pinseeker 1500 seems to have lost the ability to read anything outside of about 120 yds, even...
(More)
My Pinseeker 1500 seems to have lost the ability to read anything outside of about 120 yds, even with a fresh battery. Inside 120 no problem, outside it just acts as though I have not sighted in on anything. Any suggestions?
