Question about Belkin (F5D7633UK4A) Wireless Router
How do I set up my wireless Belkin F5D7050, I no longer have the CD. My computer has Windows Vista?
    Sergeant:
  • 175 Answers
Again verify your product's model and download proper drivers from;
http://web.belkin.com/support/download/download.asp?query=f5d7050&lang=1&mode=&Search=Search
Regards;
Hassan
Posted on Jul 12, 2009
  • 854 Answers
1. Hard wire your pc to the router/modem using ethernet cord / cat 5 cable or use usb storage to download the driver to this link
http://web.belkin.com/support/article/?lid=en&pid=F5D7050&aid=5381&scid=0
2. Install the driver/software by executing the file.
then follow this:
SymptomNot able to go online only with the wireless connection.
ResolutionTo address the problem, use the following steps:
  1. On the Belkin Wireless monitor utility click on the tab AP List .
  2. Select the encrypted network that you wish to join. Click Connect.
  3. This will take you to the New Profile page . Enter a Profile Name .
  4. On the next page, you will see the network name, the network type and the transmit rate. Click Next.
  5. This will take you to the page that will ask you to select the Authentication Mode. This will be OFF by default. Select Open System or Shared Key depending on the network.
  6. Then select 64-bit or 128-bit encryption depending on the configuration on the Router/AP. Click Next.
  7. On the next page, select Input Method , which will be Hexadecimal (0-9,A-F) or Passphrase.
  8. Select the key index and enter the keys or the passphrase depending on the configuration on the router/AP. Click Complete.
CauseYou are not able to connect to a secured wireless network because the router/AP (what is this?) is encrypted.
SummaryWireless networks by their very nature are not secure because data is transmitted across open (i.e., air) media. This allows unintended “listeners” to receive the data. WEP (Wired Equivalent Privacy) is used in a wireless network to secure the signals and hence the data.
Connection problems
1.Visit: www.belkin.com/support
2. On the top right corner, there will be a search by keyword, a small rectangular blue box
3. In that, type in: F5D7050 and press enter
4. It will give you search results, select the result that says "Drivers".
5. Select the appropriate version for your model. Belkin has 5 versions for the same model. Check for FCC no. on your device. There would be a table on that web page.
6. Verify, download and install
Feb 18, 2010 | Belkin (F5D7050) 802.11a/g/b Wireless...
I have an older model belkin f5d7050 and have the 4xxx drivers installed on windows vista 64 (which belkin says is compatible) and I get limited or no connectivity when attempting network access... I'm...
Some network adapters have problems with wireless encryption, try turning it off at the router and connect again. If it works, you wont be able to use that usb adapter with your routers encryption on.
Nov 04, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
New Belkin not working
You may have conflicts with older driver and newer one, you will need to uninstal the belkin drivers and start again, making sure you install Vista drivers, the cdrom may not have them on, only XP
Jul 20, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin lost cd
The drivers available from Belkin are exactly the same drivers as are on the PC. Someone emailing you the drivers isn't going to get you any closer to a solution if you haven't got the ones you downloaded to work.
One problem you might be having is that the driver isn't the correct version. Belkin have five different versions of drivers for the five different versions of that model of card. Make sure you're using the right one. An article about the method of identifying your particular model, together with links to the various software packages can be found at http://www.belkin.com/support/article/?lid=en&aid=5381
May 18, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Lost cd
hello shellyw
pop in to belkin here
Belkin : Support : F5D7050 Drivers
and you can download the drivers that you need to your pc .
good luck
riz.
Apr 16, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin lost cd
Spend 30 bucks on a new adapter. I have a version 4 adapter that I use as a paper weight for the same reason. I check back and search for solutions about once a month and have spent hours trying to fix a $30 part. How much is your time worth.
Apr 01, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Can't connect to the internet....
buy a better one - netgear or something less cheap and nasty
_Ahoy_
Oct 26, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin (F5D7633UK4A) Wireless Router Logo
309 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
