Question about Samsung SYNC SGH-A707 Cellular Phone
T9 texting numbers
When i go to type certain words in my text they turn into numbers and it is because on the sending bar i accidently was typing and then i went to the space were you are supposed to type your message and it started typing numbers when i wrote certain words instead of the word. How do i fix that?
  • 1 more comment
  • Anonymous Dec 06, 2007
    I have the same problem, I typed into the bar at the top and there is no way to delete words out of the dictionary.
  • AprilMDinius May 10, 2008
    This solution did not work for me. "the" still comes up as "tgd" and "be" comes up as "23". Help!!!!!
  • a_squidney May 13, 2008
    yep got the same problem
From "Best Solution".........(quote) "alright type the word that you want (ie.Hey) it will show up as 439. then go through the words until you find "Hey" then hit space twice and do it over again. after a couple times it should pop up as "hey" first instead of 439."......My Comment would be that this absolutely works!!!! YEAH!!! I've had this problem for so very long and no one at the AT&T store could help.....but.....the longer you've had the problem the more times you have to type and change the word. My phone was selecting 843 for the word "the" had been going on for, it took about about 60 times typing and changing and spacing before "the" came up as the first choice word
Posted on Jan 21, 2010
I am having the exact same problem and i just figured it out!!!
Ok, so i accidentally started typing "you" into the phone number box instead of the actual message box so then it would start coming up as "968" every time I wanted to type "you". Here's how I just fixed that:
Go to a new message and in the actually message box change your setting to "abc" instead of T9abc. Then I just typed in "you" and highlighted it with the Text Selection (option 2 in the message menu) then I pressed the Zero key. I then exited that message and reopened a new one and change it back to T9abc and typed in "you" and it worked!!! The number are gone!
I've been messing with it for the past half hour so I hope this helps you guys!
Posted on Jun 01, 2008
The solution #3 worked for me.  thanks.  that was really annoying.  i had 968 instead of "you" so i typed two pages of "your" and it finally figured fixed it.
Posted on Jul 28, 2008
The fix depends on how bad you want to fix the problem.. The tip about typing the word, hitting '0' to change it to the word you want instead of the numbers works, it just can take a while. My problem was the word 'what' kept coming up as 9428. It took 3 pages of typing 9428, changing it to 'what', then spacing twice before it finally quit doing it. Keep at it. eventually your phone will figure it out.
Posted on Jul 16, 2008
It seems to work on words that are newly "wrong", but for words that haven't "worked" (been right) for a long time, it doesn't. i'm going to try a full reset.
Posted on Dec 28, 2007
Alright type the word that you want (ie.Hey) it will show up as 439. then go through the words until you find "Hey" then hit space twice and do it over again. after a couple times it should pop up as "hey" first instead of 439.
you can use that on any word you want.
Posted on Dec 25, 2007
How can one type with a normal typing keyboard rather than hitting abc for a c?
If your phone only has the numeric pad you can change the setting from "abc" to "T9". T9 is a predictive texting mode, so if you wanted to type the word "hello" you would just press the corresponding numbers 1 time, for example: 4(gHi)-3(dEf)-5 (jkL)-5(jkL)-6(mnO), so you would only hit 4-3-5-5-6, if the word is not the first word displayed you can hit the next key which is usually either * or # depending on your phone. The T9 setting is usually changed by again hitting either the * or # key, or sometimes 0. It is also sometimes selected on the texting menu from within the message.
Learn how to use T9
Sep 06, 2011 | Cell Phones
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Daughter borrowed phone and switched the text msg typing to auto fill and numbers. I have tried every thing and I can't figure it out, can you please help me? Thank you, Susan
Based on your description, what you are referring to is called T9 Predictive Texting. It allows words to be entered by a single keypress for each letter, as opposed to the multi-tap approach used in the older generation of mobile phones in which several letters are associated with each key, and selecting one letter often requires multiple keypresses. Example, when typing the word 'love' in a T9 activated phone, all you have to do is press the numbers 5, 6, 8 and 3 once in sequence. As compared to the regular texting, in order to complete the word 'love', you have to press the number 5 thrice, the number 6 thrice, the number 8 thrice, and the number 3 twice.
If you want to disable T9 predictive texting, it can usually be disabled by pressing and holding the hash or number key (#).
Hope this information is helpful.
Apr 08, 2011 | LG Cell Phones
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
When I am writing a text message the phone starts predicting words. I just want to send a simple email without any ''help''
If you are seeing the T9 icon on your screen, this is the T9 Text input feature of your phone. It act's like a built-in dictionary for commonly used in a sentence.
To disable this, while on writing mode, press and hold * key to disable text input.
Sep 25, 2009 | Sony Ericsson K850i Mobile Phone
When typing a text, I can't pick the letters or numbers I want.
that means your messaging font is set to type the word for you. find "options" then look for soomething that ays "abc" your phone is set to type in "t9"
Apr 09, 2009 | Nokia 6085 Cellular Phone
If you have accidentally saved a word into the T9 dictionary (ie, "IS" comes up with "47" or "Get" comes up with "HDU", you can teach the dictionary to revert back to the original word.
What you have to do is..... create a new text message, enter the text that is annoying, (ie, "IS"). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again - you can do this in the same text message - it can take up to 20 goes but eventually, the dictionary recognises that you actually wanted "IS".
Nov 09, 2008 | Samsung U900 Soul Cellular Phone
Reset the T9 text dictionary
I ran into this problem as well, and it is extremely annoying. I just lived with it for the longest time and then I finally decided to go looking for a solution. That came to a quick end when I found the Samsung FAQ and it said that there is no way to delete words from the predictive dictionary. However, that got me thinking. If it's predictive, can I teach the predictive to write the correct word? The answer is YES! Open a blank text message, don't worry about a number just go to the text entry portion. Type out the word and press zero to change it to the correct word instead of the numbers. Do this 10-20 times IN A ROW and then the phone will recognize the right word as being most used and change it back to that.
Sep 25, 2008 | Samsung SGH-a737 Cellular Phone
Texting and taking off the t9 feature of assuming what im going to type
sometimes it will pop extra words up like that for me, but i found that if you just ignore it and keep typing, they will go away. try it :)
Aug 18, 2008 | LG Shine KE970 Cellular Phone
Texts random letters and then sends on it's own
have you tried to change the TEXT T9 from iTap to just ENGLISH
Dec 29, 2007 | Motorola Mobility RAZR V3
Samsung SYNC SGH-A707 Cellular Phone Logo
1,120 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
