MagnaFlow 2005 Lincoln LS - 3.9L V8, with federal emissions system - Catalytic Converters - 49 State Legal Logo
Posted on Sep 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have question on firing order identification .
Told to replace cylinder E ignition coil. How does that compare to the numerical cylinders, ie cylinder LH side 1234. RH side 5678.
Bill Boyd
Level 3:
Top Expert:
  • MagnaFlow Master 53,816 Answers
  • Posted on Sep 18, 2015
Bill Boyd
MagnaFlow Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948942
Points
172802
Try the alphabet as numbers as numbers so that 1234 would be equal to abcd and 5678 would be efgh if that is correct the e coil would be on no 5 piston plug
that is if you have 8 individual coils for the pistons
Looking for the firing order for Hyundai s coupe 1.5 LS
NO YEAR TOLD... 1993 TO 1996?
CORRECT NAME (NO SPACE BEFORE C)
Hyundai Scoupe? ALL 4 BANGERS ARE 1,3,4,2
EXCEPT BOXER ENGINES (PANCAKE MOTORS)
IS THIS A SPARK QUESTION?
OR CAM TIMING QUESTION.?
2answers
Firing order 89 Ford f250 lariat 4x4
limited info generic answer --this is small block 1-3-7-2-6-5-4-8 with number one being front passenger side and number 5 being front driver side
Whats the firing order for a 1990 Kawasaki 600 zx ninja.
The ZX6, as with most four-cylinder motorcycle engines, is mounted transversely in the frame. When sitting on the bike, the cylinders are numbered 1-2-3-4 left to right.
Firing Order: the firing order is 1-2-4-3. There is no distributor for the engine, as ignition is controlled electronically.
Extra Ignition Information: there are only two ignition coils for this engine. Each coil has two spark plug wires. One coil fires cylinders 1 and 4. The other fires cylinders 2 and 3
4helpful
NEED SPARK PLUG WIRING DIAGRAM FOR 2001 v6pontica aztek
I assume you mean "Firing Order and Cylinder Identification" diagram.
Please note that the OEM ignition coils on your vehicle are marked with the cylinder numbers. See diagram.
5helpful
WHAT IS THE FIRING ORDER FOR KAWASAKI ZX600R
Extra Ignition Information: there are only two ignition coils for this engine. Each coil has two spark plug wires. One coil fires cylinders 1 and 4. The other fires cylinders 2 and 3.
Addtional details in this link: images/4/45/ZX600E13.PDF
hope this helps (remember to rating this free answer).
Firing order need to know what plug is number 1 and what plug on coil pack is number 1
For the 1993 Chevy Lumina:
I do not know if you have the 2.2L In-Line 4 Cylinder, 3.1L V6, or 3.4L DOHC V6 Engine; however I have included all below.
For the 2.2L (4-Cylinder)
Firing Order:
1-3-4-2
Cylinders:
......(back)
1.....2.....3.....4
......(front)
Ignition Coil Connections:
o <---4
...o <---1
......o <----3
.........o <----2
For the 3.1L V6:
Cylinders:
...(back)
5.............6
3.............4
1.............2
....(front)
.|.1..4.|..|.6..3.|..|.2..5.|
For the 3.4L DOHC V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
.......(back)
1........3.........5
2........4.........6
.......(front)
.|.1..4.|..|.3..6.|..|.2..5.|
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
3helpful
Firing order diagram for a 96 dodge caravan
For the 2.4L:
Firing Order:
1-3-4-2
Cylinders:
1---2---3---4
(front of Van)
Ignition coil:
1----4
2----3
(front of the Van)
For the 3.0L
Firing Order:
1-2-3-4-5-6
Cylinders:
1----3-----5
2----4-----6
(front of Van)
Distributor:
-----2-----1------
3----------------6
-----4-----5-----
(front of Van)
For the 3.3L:
Firing Order:
1-2-3-4-5-6
Cylinder:
1----2----3
4----5----6
(front of Van)
Ignition Coil:
6---3
4---1
2---5
(front of Van)
For the 3.8L:
Firing Order:
1-2-3-4-5-6
Cylinders:
1---3---5
2---4---6
(front of Van)
Ignition Coil:
6---3
4---1
2---5
(front of Van)
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
8helpful
2answers
Need firing order and, I need to know what side the number one piston is on?
To avoid confusion, remove and tag the spark plug wires one at a time, for replacement.
The 3.5L (VIN H) engine's unique ignition system has the ignition coils directly over each plug. No spark plug wires are used.
If a coil is replaced on any of the 3.1L, 3.4L or 3.8L engines, it may not be numbered, as is the factory coil. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your guide to reflect how your engine is wired.
Fig. 3.1L (VIN M) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.4L (VIN X) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.4L (VIN E) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.5L (VIN H) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.8L (VIN 1) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
Fig. 3.8L (VIN K) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
The firing order for the 3.1L VIN M, 3.4L VIN E, 3.4L VIN X and 3.5L VIN H engines is 1-2-3-4-5-6. The right bank cylinders are on the cowl side (rear) of the engine compartment and are numbered 1,3,5, left bank cylinders on the front side of the vehicle, are numbered 2,4,6.
The firing order for the 3.8L VIN K and 3.8L VIN 1 engines is 1-6-5-4-3-2. Starting at the front of the engine, cylinders in the left bank are numbered 1,3,5 and cylinders in the right bank are numbered 2,4,6
Hope helped (remember rated this help) Good luck.
5helpful
Ignition firing order and cable position at the coils
The firing order for the 3.8L VIN K and 3.8L VIN 1 engines is 1-6-5-4-3-2. Starting at the front of the engine, cylinders in the left bank are numbered 1,3,5 and cylinders in the right bank are numbered 2,4,6.
I hope help you with this, remember rated this help. Good luck.
6helpful
2answers
Fireing order for a 1987 oldsmobile delta 88
2 different 3.8's for that. Will send other picture as well, you pick what you have.c50fb60.jpg
Top MagnaFlow Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a MagnaFlow Electronics - Other Expert? Answer questions, earn points and help others
