Question about Star Logic 17" LCD Monitor
My monitor say out of range and no in put siginal be for this it said DVI disconnected. I can plug it into 2 other computers and it works. HELP
  • sidneywoody2 Jul 12, 2009
    it has worked on 3 other computers. I hooked up an other monitor it did not work either.
  • skootzilla May 11, 2010
    Can you test another monitor on computer? Sounds like a video card issue.
    Problem Solver:
  • 5 Answers
This problem is the screen resolution that your computer is set at. Start the computer enter safe mode, press and hold F8 as windows starts. change the resolution right hand mouse click on desk top, click on properties, lower the screen resolution, and re start. I hope that helps.
Posted on Jul 13, 2009
I can't get either of my 2 computer monitors to work through my DVI D cable, both monitors work through a VGA cable, just the DVI wont work, what is wrong?
dvi cable most likely will only work as a second monitor rather than as a primary monitor. Suggest checking you computer video card specifications to see if this is the case.
Apr 23, 2018 | Vga Computers & Internet
HOW to reset Compaq S2021A LCD Monitot
* Power the monitor off
* Disconnect all cabling from the bottom and/or sides of the monitor (especially the power cord)
* Press and hold the monitor power button down for 5 seconds
* Reconnect only the monitor power cord and either the #1 blue VGA or #2 white DVI (not both from one video card)
* Power the monitor on
* The PC should already be on. The monitor should auto sense the #1 blue VGA or #2 white DVI. If it does not, press the Input Select button and change to #1 VGA or #2 DVI
Jul 02, 2013 | HP Computers & Internet
Monitor displays frequency out of range.....need help . How can I solve this?
The frequency is out of range because the VGA graphics card is not compatible or set right for the monitor's set of frequencies that it can work with.
Try another VGA graphics card.
Or upgrade the card to one with DVI, and upgrade the monitor to one of those 24" DVI Samsung monitors. They're nice. I got one from Best Buy a few years ago, and never regretted the larger desktop.
Good luck on this one.
Jul 10, 2010 | E-Machines eMachines Monitor E15T4
My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Ps3 to gateway fdp1760 frequency out of range dvi to hdmi cable
what Frequency is the monitor set to run at ? u will get that mesg whan the monitor is receiving a signal that is greater than what it can handle say ur monitor can take 1024x768@60hz from ur PC and maybee ur PS3 is sending 720x720@100hz so ur monitor can handle the resolution but not the refresh rate that would be why u get that message
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Can you help I have just treat myself to sky hd my monitor has a dvi socket on the back so I got a hdmi to dvi connector the problem is the monitor displays a out of range message ! any ideas ?
Hi...there,
Your screen resolution settings are to high...plugged into another monitor right click and go to properties and click on settings to resettings by moving the bar back to 1 or 2 knots from your monitor.
Oct 19, 2008 | BenQ FP91G+ 19" LCD Monitor
Cords
According to the manufacturer, you have two plugs available for video. Either will work fine. The first is the traditional RGB plug. It contains 3 rows of 5 pins, and typically is blue in color. The second (and better IMHO) connection method is the DVI cables that many LCD's now come with. However, you will need to have a DVI connection on whatever you're plugging this monitor into. The plug is much wider than a traditional RGB plug. You monitor will specifically use the DVI-D (DVI-Digital) plug as seen at monoprice.com (http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10209&cs_id=1020901&p_id=2685&seq=1&format=1#largeimage).
Manufacturer page: http://www.rosewill.com/products/s_214/productDetail.htm DVI Plug Types: 26854.jpg
Good luck! Steven
Sep 16, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Monitor goes blank after showing XP logo screen (black screen with the xp logo right after boot up screens)
There are different reasons why this might happen. Let's try some. 1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!) if not then 2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try Well if that doesn't work, tell me more! Regards, Armando
Apr 28, 2007 | XFX GeForce FX 6800 (256 MB) Graphic Card
Star Logic 17" LCD Monitor Logo
120 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
ray gallant
jd83854
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
