Question about Hotpoint Dishwashers
Water remains in bottom of Hotpoint dishwasher.
Just bought a used (very new-looking) Hotpoint dishwasher & started it at Normal wash cycle. It goes thru like everything is OK, except leaves water in bottom of washer when it completes its cycle. Water remains to a height of the bottom of door, though no water leaks out of the dishwasher itself. I ran it thru 2 Normal wash cycles and it leaves water in the bottom section each time. Is this normal? The appliance guy I bought it from does not service the d/w (???...don't ask me why).
  • 183 Answers
SOURCE: It's Leaking Water!
Most common reason is that the lower spray arm splits on the seem and sprays water under the door, to proove if it is this remove lower spray arm and run through program if no leak fit new arm. Regards Advisor
Posted on Aug 31, 2007
  • 209 Answers
SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Posted on Sep 16, 2007
  • 17 Answers
SOURCE: vulcan dishlex mark 8 leaking water from bottom front door in wash cycle.
try adjusting the feet at the front of your dishwasher so it leans back slightly to keep the water towards the back of the washer
Posted on Dec 11, 2007
robotek
  • 1512 Answers
SOURCE: greasy bottom in dishwasher
Hi there, you can get a product that has extra cleaning power designed for dishwashers to clean stubborn grease and calcium deposits. It works great and also clean up the waste hose and pump and valves in the machine. If the door seal is covering the grease in the front corner, you may have to clean it yourself as theat places it outside the washer.
regards
Graeme
Posted on Mar 08, 2008
futureloginn
  • 734 Answers
SOURCE: Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Bf72 not doing the wash cycle correctly
If you are using hot water connection then check the temperature of incoming water is hot enough. If cold water inlet only is used then most likely the heater element or thermostat in the dishwasher is faulty and the water is not heating enough.
Nov 04, 2012 | Hotpoint 24 in. BF72 Built-in Dishwasher
The drain is not clogged or blocked and the line is not kinked. The hoses are not blocked & the air gap clean. The disposer has not been replaced recently. The drain hose from the disposer to the air...
their will some water that always remains in the pump below the fliters is should never be visible in the tub once cycle is over but it must always be there to keep the seals moist to prevent them from dry rotting
Aug 26, 2011 | Hotpoint 24 in. HDA3400G Built-in...
My dishwasher model No. is Hotpoint BFI680, There was water lying in the bottom after a wash and it couldn't be restarted, I cleaned it out and took out the drain pump and connected it up to 240volt and...
Hello!
As the manual says:
If water remains inside the
dishwasher, check:
the drain hose is not kinked.
the drain syphon is not
obstructed.
the dishwasher filters are not
clogged.
i also add a link to this manual, hope it will help
Hotpoint BFI 680 User Manual Page 13 of 20
May 23, 2017 | Dishwashers
Water in the bottom at the end of the cycle
check the drain spigot under the sink to see if there is a blockage.also you can fit a check kit to the drain hose.you can get it from asko
May 31, 2010 | Asko D1706 Built-in Dishwasher
Water remains in the bottom of dishwasher (in the salt dispenser)after the wash cycle has finished
it is normal for water to be in the bottom of a dishwasher- it forms an air seal to stop odours
Aug 28, 2009 | Dishwashers
Hotpoint DF23: Wont go through full cycle
Sounds like you may have to replace the cycle timer.
Oct 28, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwashers Logo
115 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
