Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
It is not sucking up the water I have it together right, but I am not getting the dirty water out of the tank It is dry when the water is gone.
  • 25 Answers
Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). It is a small (1 inch square) red plastic filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre, etc.. Clean it out and you should have proper suction once again.
Posted on Sep 18, 2009
Rapide XL. Why isn't it sucking up the dirty water?
you need to set it lower for water
Aug 10, 2015 | Vax Vacuums
Dirt devil spot scrubber not picking up
Hi there! There are a few reasons why your spot scrubber may not be picking up. Your dirty water tank may not be seated properly or the filter may be dirty Please try these steps.
1. Check the filter located on top of the dirty water tank. If dirty, rinse with water.
2. Check that the pour spout cap on dirty water tank is plugged.
3. Replace the dirty water tank. Make sure the dirty water tank is flush to the cleaner and seated properly.
4. Clean the nozzle of any hair or debris.
Hope this helps! For further assistance please feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Jul 03, 2014 | Dirt Devil SE2800 Spot Scrubber Handheld...
No suction
open the tank where dirty water goes and make sure the float is down and not stuck ...when its full of dirty water the float raises with the water level so that the vacuum doesnt keep sucking and overflow
Jan 03, 2010 | Dirt Devil CE5500 Floor Keeper Upright...
My steam vac stopped sucking the water up
make sure the lid on the dirty water container is on tight and the tank itself is locked into place, also check to make sure the clear window in the front of the machine is tightened down firmly
Oct 20, 2009 | Hoover F5858-910 SteamVac Vacuum
HOW DO i GET THE WATER OUT OF THE CARPET ONCE IT'S CLEANED?
Do you have a shop vac . Take the bag out of the shop vac ,and **** up the water . When you are done open your windows and do not walk on the carpet for at least one hour . You want your carpets to dry with the pile standing up. Carpet rake is the best thing to use . Best of luck Ed.
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My bissell ready dry doesn't clean my carpet.
my bissel ready dry is not sucking the water up
Mar 30, 2009 | Vacuums
Dirty Water drops behind shampooer
You are over sudsing your recovery tank. The machine is made to shut off the air flow if water starts to be pulled into the motor, but bubbles want trigger that. So if there are a lot of bubbles in your recovery tank, the get sucked into the motor (Which will destroy it eventually) and then the moisture gets exhausted onto the floor from the motor.
Solutions
1. Use less soap (Read the directions, you may be using too much)
2. Use a different kind of soap (The concentration might not be right for your machine)
3. Use a defoamer (Rug Doctor has a defoamer)
Nov 14, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a Bissel proheat 7901 carpet cleaner and it is not sucking the water up. Normally when I clean the water gets sucked back up and I have to empty the dirty tank. Now no water is in the tank when I am...
I'm not sure if this will help but I had the same problem and was about ready to pull my hair out. I ended up taking the fill tank off and if you look inside where the red overflow flap is you will find a small screened opening. I found that mine was pretty clogged up with debris but once I removed the mess and put my machine back together it is now sucking like a champ. I hope this helps. Here's hoping that you don't have the pay for a service person to look at it.
May 18, 2008 | Vacuums
Hoover steamvan cleaner F5807
If this has a duct part #38661003 (#3) that is supposed to be installed in front of the tank isn't there, then you will have no suction to pick up the dirty water.
If this doesn't use a duct, then either the foam filter (#2) is up all of the way, need to leave 1/4 in. gap from the top, or the rear of the tank lid is not locked down.
Jan 22, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
