Question about Audio Pro 15PLB76 15 Inch 800 Watt Woofer Car Speaker
Speaker size for 2007 toyota Tacoma Supercab - Audio Pro 15PLB76 15 Inch 800 Watt Woofer Car Speaker
  • 11 Answers
The fronts are an odd mount tweeter and a 6x9 and the rears are 6.5 inch.
The front speakers require a special mount.
Posted on Jul 12, 2009
How do I axcess the fan motor in the 2007 tacoma
The air conditioning fan motor is located under the glove box. Three bolts, forget the size, but about an 5 or 6mm (7/32 i rumored to work well). Pull the plug out after you drop the motor.
Picture of 2 of the three screws here.
http://www.toyotanation.com/forum/61-2nd-generation-2005/246763-hvac-blower-motor-resistor-replacement.html
The connector is shown here
http://www.toyotanation.com/forum/61-2nd-generation-2005/361736-ac-heater-blower-motor-failure.html
Jul 14, 2014 | 2007 Toyota Tacoma
Will a 2004 toyota tacoma camper shell fit a 2007 toyota tacoma truck ?
Hi Dana, If you are asking if the engine, gearbox and other parts can be inter changed the answer is yes. Regards John
Sep 21, 2012 | 2007 Toyota Tacoma
Need wire diagram for 2001 toyota tacoma for installing JVC kw-nt3hdt stereo or any advice
Hi, here are your factory wire colors/functions. Aftermarket stereos have a common set of colors, which should be in your installation diagram. The process is simplified if you purchase a wiring adapter for your vehicle. These are available for under $10 at most WALMARTs and auto parts stores or about any place that sells car stereos. In either case, I recommend you solder the connections or at least use crimp terminals. If you have any more questions, please let me know--I've done a lot of stereo installations.
2001 Toyota Tacoma Car Stereo Installation Guide
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jan 07, 2011 | 2001 Toyota Tacoma
Replacing front struts on a 2007 toyota tacoma
REALLY HARD PROJECT, TAKE IT TO SEARS, IT WILL ALSO NEED FRONT ALLIGNMENT
Jul 25, 2010 | 2007 Toyota Tacoma
2002 4x4 tacoma replaced radio now door chime and stereo doesnt work
2002 Toyota Tacoma Car Stereo Wiring Diagram
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Corners
Recheck your wire connections, good luck.
Thank you for using Fixya
Mar 19, 2010 | 2002 Toyota Tacoma
Toyota tacoma 2007 stereo wiring Colors for the following wires: Power-ignition Ground
Radio 12v blue/yellow + radio harness
Radio Ground brown - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- pink - purple +,- radio harness or amplifier
RF Speaker +/- lt. green - blue +,- radio harness or amplifier
LR Speaker +/- black - yellow +,- radio harness or amplifier
RR Speaker +/- red - white +,- radio harness or amplifier
Notes: If equipped, the amplifier is on the passenger side rear cabin wall.
Sep 13, 2009 | 2007 Toyota Tacoma
2007 Toyota Tacoma key fob
no.. u need to have a dealer do it.. they also have a tool ti check it the remote is transmitting a signal as well
Jul 27, 2009 | 2003 Toyota Tacoma
Car Audio & Video Logo
529 people viewed this question
Top Audio Pro Car Audio & Video Experts
xxxxxx xxx
Are you an Audio Pro Car Audio and Video Expert? Answer questions, earn points and help others
