Question about RCA S1000 MP3 Player
My mp3 lock is stuck. Please Help!
The lock/unlock switch moves back and forth but, when you turn it on it says keys locked and it cuts off. Any suggestions please?
  • amberrose23 Nov 25, 2007
    Same problem. I have 2 of the same model and they both had the same problem. The lock switch iis in the unlock position. I've reformatted it and everything. I got one unlocked, but I have no idea how.
  • Aveon Apr 09, 2008
    my mp3 is having the same problem and it seems to be a popular problem either i need a solution or my money back
I contacted RCA and they said to make sure that the switch on the side is in the unlock position. If that does not work resest it by taking the battery out for one minute. That did not work for mine so she said it was defective. Since I did not have a receipt or an exact date of purchase, they will only refund me $42.55, and I think it only has a one year warranty, after that your on your own. Hope this helps.
Posted on Nov 26, 2007
My daughter's player had this problem. Would not unlock. The lock switch on the pc board was worn out, loose, or just plain defective. To fix, I opened the player's case, clipped the inside tabs on the plastic lock lever and made sure the pc switch was in the unlock position, then reassembled. Lock function is now disabled permanently, but the buttons are stiff enough. Still haven't fixed the broken batt cover, but at least she can use it now. RCA S1000A
MODMAN BRJ
Posted on Jan 04, 2008
How do I unlock the steering wheel when the key won't turn
You can't. Wiggle the key and move the steering as much as possible back and forth as you do it. You can also strike the lock cylinder with a hammer handle, this may dislodge the stuck ignition lock cylinder pin.
May 11, 2016 | Cars & Trucks
I CANNOT UNLOCK MY TOSHIBA MP3 PLAYER
Can you be more speisific about your problem?
Jun 27, 2008 | Toshiba Audio Players & Recorders
ZUNE LOCKING SWITCH
Well I guess I'll be using it too on the new Zunes because I think they are going to be a lot more sensitive with the touchpad
Mar 01, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Ignition switch key lock solenoid passat
when you shut it off were the wheels cranked sideways-sometimes this puts pressure on the locking system and won't let it disengage-try moving the steering wheel back and forth while applying pressure to the key-I hope this helps-cheers Denny
Nov 08, 2013 | 2004 Hummer H2
Key is stuck in ignition. Depressing the "unlock"
Somtimes you need to turn the steering wheel a little to allow the lock to engage.
Try depress the unlock button while moving the steering back and forth a little. Try a lot..
If not work, drape a scarf or towel over steering column to hide key in ignition, and use spare key to open door lock. You do have spare key?
Check your insurance, you may have lock smith lock out coverage.
Good luck.
Feb 27, 2011 | 1990 Nissan Maxima
2001cav 2.2 put the key in and can't turn itj everthing is locked up any ideas.
Does your vehicle have a security system? If so, it might need reset. This would cause it to lock up. Try moving the steering wheel back and forth, left to right, while you are trying to turn the key. You might be able to get it unlocked this way. Your steering column may have locked up. If not, you may need to get a new ignition switch. I would try moving it back and forth. Don't be afraid to give the steering wheel so major pressure. Hope this helps.
Feb 06, 2011 | 2001 Chevrolet Cavalier
I have an 86 4runner with the steering wheel locked
turn the steering wheel back and forth while turning the key @ the same time
Oct 03, 2009 | 1998 Toyota 4Runner
Lock problem (zune 30)
If it's a zune 30, it's just a glitch in the software timing and so you have to flick it back and forth until it works.
My zune does the same exact thing, it always has. So just bare with them (:
hoprfully microsoft will create a software or firmware update that help itt. (:
Mar 29, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Error on printer
There is a safety lock on the scanner that may be in the locked position. Turn the unit off and locate the green lock lever/switch under the scanner where the paper comes out. It will be labeled with a icon (picture) of a lock (unlocked and locked). Move it to the unlocked and locked position multiple times, ending up in the unlocked position. It may be stuck so moving it back and forth may release it. Turn it back on and try it.
Mar 17, 2008 | Office Equipment & Supplies
RCA S1000 MP3 Player Logo
193 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
