Question about Star Heating & Cooling
Potble ac unit w/broken fan need a new part for it!!
    Problem Solver:
  • 11 Answers
Dental technicians lubricate dental handpieces to keep moving parts and hinges free of rust and corrosion. The water-based lubricant provides a protective shield to prevent instruments from dulling over time, and extends the life of the expensive handpieces. This lubrication process, called "instrument milking," is mandatory before sterilizing instruments.potble ac unit w/broken fan need a new part for - 8_24_2012_9_44_43_am.jpg
Posted on Aug 24, 2012
    Champion:
  • 233 Answers
Generally speaking depending on the size of the unit it may be chaeper to buy another than repalce the fan motor, I assume you are talking about a window unit. By the time you source the part, gut the unit , replace the fan, and reinstall it, the labor and parts is well over 2/3-3/4 of the cost of a new unit with a warranty
Posted on Jul 12, 2009
I have a Coleman mach RV roof Ac with a fan and separate Furnace unit. None of the units will turn on.The AC did work along with the fan. Now nothing works. All of the fuses are good
Check the plug end of the Power cord for a broken wire. If you can test the cord for continuity with an ohm meter do that first. Most likely you can get a replacement plug. You'll need to cut the old one off and strip the wires back to connect the new plug.
Feb 09, 2017 | Coleman Heating & Cooling
No fan when ac kicks on Ihave a eb15b funace with a coleman ac
The heat will normally use a low speed on the fan, & the AC along with the fan switch on the thermostat will use the high speed. The thermostat turns that high speed on when there is a call for cooling & is the same switch if you were to manually turn the fan from auto to on. Try turning the fan on @ the thermostat. If it works, then replace your thermostat. If it doesn't, it could be a bad fan speed, a bad fan relay on a control board or external relay, or a loose or broken green thermostat wire.
Apr 14, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
Goodman ckl36-1e
You do not need a new unit ,it can be fixed, good luck finding an honest tech
Jul 01, 2013 | Heating & Cooling
All lights on but fan or nothing works also can't find reset button
Do you have an owner's manual that came with it? If so you should contact the manufacturer and find out what services are available. It is not something the amateur can fix since it is high voltage and solid state on a circuit board or two. Maybe there are error codes you can write down like the "19" may be,
Jan 01, 2013 | Heating & Cooling
Need Instruction manual for MPK-10CR
You can find the Use & Care Manual for your Everstar MPK-10CR here:http://www.supportuscenter.com/documents/MPK_Manual.pdf
The warranty & repair services for this unit are handled by Midea. I would suggest contacting their staff for the part.
Contact for Technical Service USA:
Contact Person: Winston Sankey
Tel: +1-305-591-8460
Fax: +1-305-591-8451
E-mail:winston@mideaamerica.com
I also did a search for you on AppliaceFactoryParts.com. This may be the part you are looking for:http://www.appliancefactoryparts.com/search/part/1371698/146072
Best of Luck!
Jul 16, 2012 | Heating & Cooling
2003 civic temps go up with ac on
Seems like the a/c radiator fan is not working. Either the fan itself is broken, or the power wires that drive it are not connected. The fan is tripped by a/c compressor activity, and goes through a relay unit, which actually trips the voltage that feed this particular fan. You can check fan activity with car parked, and turning on the a/c . if you cant recognize the louder noise of this fan, stick a straw into the fan to check if it is turning. Careful with fingers.
Apr 23, 2010 | 2005 Honda Civic
2003 trailblazer loss of cruise control and ac fan
for parking brake and abs check for parking brake switch operation, for abs check with scan tool for any trouble code, for your cruise control unit check for any broken vacumm hoses on the engine, for the ac fan, check the fan motor, relay or fuse.
Jul 16, 2009 | 2003 Chevrolet TrailBlazer
My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
May 11, 2009 | Carrier 38CKC036 Air Conditioner
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Star Heating & Cooling Experts
Paul Carew
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a Star Heating and Cooling Expert? Answer questions, earn points and help others
