Question about Philips Irons
My Philips Azur 4200 is leaking from the little hole on the back end of the iron.
4 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: help
heres a link so you can get more information for your product , hope this helps AJ .
http://www.shopping.com/xPP-irons-norelco~LO-1~CR-0
Posted on May 17, 2008
SOURCE: Problem with Philips Azur Precise 4340 Iron
i had the same problem and the Philips hekp site was no use. I turned my iron off until it was completely cooled down then switched it back on again, with the steam number turned to 5 and the heat on max. as soon as the ready light went off, i put my iron in the horizontal position and shook it back and forth (quite vigorously) and it seemed to have dont the trick!
Posted on Aug 28, 2008
SOURCE: Philips Azur 4200 Iron spits out water like a water gun, burning my hand when ironing
i think you will find the solution is an easy one...you could wear some overalls and protective work wear....or.....stick some blue tack over the hole.....or .....get your husband to do it.
Posted on Jun 20, 2009
WHERE IS THE SERIAL NUMBER ON THE PHILIPS GC4890/02
I remember reading a # stamped right on the prongs of the plug in. Let me know if that works!
Jul 10, 2014 | Philips Azur Gc4890/02 Steam Iron With...
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
I can find only one screw in the housing of the ep 8000 iron. What kind of screw driver does it take? Allen wrench doesn't engage.
Sounds like a 'TORX' head.
Does it look like a 'star' inside the screw head? A six-sided star? If so, then it is a TORX head.
Look carefully at it, and determine whether or not there is a small pin sticking out of the center.
The screw you are trying to remove is either a Flat-Head (-), a Philips (+) or a TORX (*).
You can get TORX bits almost anywhere, from the Hardware store, the Auto-parts store, to a Dollar store. You can get them with, or without, the little hole for the pin in the head.
You will probably want to buy a little 'set' that has multiple sizes of bits, and a driver, with an extension for reaching into those deep holes.
Jun 24, 2011 | Euro-Pro Steam Generator EP8001 Iron
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
Steaming function stop working
its just connected with a screws on the front flap that has to be opened to seperate it into two parts,and inside there is small black coil thats is connected to the wires that wires must be short so has to be replaced with another wires. do it carefully .take care.
Feb 26, 2009 | Philips Irons
Nov 03, 2008 | Irons
Jul 09, 2008 | Irons
Help
May 17, 2008 | Philips HI-296 Iron
Philips Azure self-cleaning steam iron
philips do not have a manual for this iron online, sorry contact them if you want; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?sct=IR_STEAMIRONS_SU&cat=HOP_IRONS_CA&grp=HOUSEHOLD_PRODUCTS_GR&session=20070313063306_83.37.63.254&ctn=HI296/54&slg=ENG&scy=GB The best way to clean these irons is with neat vinegar - try to get white vinegar and you have less smell to get rid of - fill the iron, give it a good shake and leave it overnight, then use the iron as normal (use it on a kitchen drying up towel or similar) then leave it for another few hours/overnight and then empty out any remaining vinegar and rinse through with water a couple of times. this normally solves any problems caused by limescale - if not then just leave the iron a little longer with the vinegar, also try to pour a little vinegar into the steam vent holes with the iron upturned and leave for a while. Hope this helps :)
Mar 05, 2007 | Philips HI-296 Iron
Irons Logo
257 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
