Question about Jenn-Air 24 in. JDB6900 Built-in Dishwasher
Won'r run unless I push the door
Thgis morning the DW stopped runing half-way thru and now it won't go on unless I lean against the door. Any ideas?
  • 248 Answers
Probably a broken latch assembly.. UNPLUG UNIT!! Remove inner door panel to access. Also check for broken tabs on onside of console where latch assembly rests.
Posted on Nov 16, 2007
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 | Dryers
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
Fuel door won't open
Fixed. In the glove box there is a vallet button. I pushed it and now my trunk and fuel door work. and what this has to do with my trunk and fuel door not functioning , I have no idea. Hope this helps someone else.
Apr 05, 2012 | 1998 Cadillac DeVille
My Maytag Neptune electric Dryer will not stop unless it is unplugged or door is opened.
check the door switch,when you open the door the dryer shouls stop,push in on the door switch and let it out,it should click when it pops out,if the switch broke pushed in it won't shut off.the part number is W10169313 and it's around 16 dollars,
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
On a 96 grand am the fule pump won't stop runing.
Running never stop,it not the wiring,check the power soure that give the feul pump it power.
Nov 24, 2011 | 1994 Pontiac Grand Am
Doesn't close tight enough to start
It sounds like your door-closed sensor (a microswitch) is out-of-adjustment. If you can locate this sensor, try gluing a tiny piece of plastic or wood to it. This will do the same thing as pushing really ******* the door and allow your dishwasher to operate normally.
Dec 26, 2017 | Bosch SHE5AL02UC Builtin Dishwasher
After doing a head gasket repair 2001 Chrysler Sebring 2.7 v6 won't start. It makes a noise like growling but does not turn over. My mechanic is saying we may need to rebuild bottom half but makes no...
You say that it does not turn over, how would you know there's no compression if it don't turn over, unless you mean if won't start up, lets go with it won't start up, if you have no compression, did you bleed down the lifter's, if you did not, with the lifter pump up will hold the valves open and you will not have compression, will be very hard to start engine, remove lifter and bleed them down, also make sure you replace the oil just in case there's water in the oil pan when heads were removed, if there is water could lock engne, now you would need to overhaul lower engine, hope this was very helpful.
Oct 10, 2011 | 2001 Chrysler Sebring
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
Jenn-Air 24 in. JDB6900 Built-in Dishwasher Logo
98 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
