Question about Craftsman Garden
I have a 2003 craftsman 6hp lawn mower. It would start and not stay running so I cleaned the spark plug, cleaned the carb and drained the fuel. It ran decent for a mow, the next time I used it I started it for and it ran for 5 minutes and died. I can get it started briefly and it surges until it dies. I noticed a kink in the fuel line and sorted that out. I suspect when it was in for servicing a few years ago that they put the wrong carb spring on it. there are no adjustments for this carburetor that I can find. Any suggestions would be greatly appreciated. The lawn is getting pretty long. Thank you, Steve and Tammy
    New Friend:
  • 93 Answers
Fuel Problem, Pull off the Carb bowl you will see the problem (Green Gunk and Varnish. When you drop the Carb Bowl you will see a hole in the carb assy. below the float, use a paperclip or other small object to clean it out........its probably plugged.
Posted on Sep 15, 2009
  • David Zawatski Sep 15, 2009
Won t stay running
could be a bad coil
Oct 15, 2013 | Craftsman Garden
16.5HP Honda engine wont run
An engine needs fuel air and spark to run. Is the air filter clean. Use a "spark checker" to see if you have spark. They are not expensive and available at stores that sell lawn mower parts. Is the spark plug clean? If it is not clean it with a wire brush.Squirt some starting fluid into the carb. If it fires your gas has gone bad or it is not getting gas. If it has sat a while gas does go bad so drain the fule tank and out in fresh gas.
Sep 05, 2013 | Craftsman Lawn Tractor Operators Manual...
My Craftsman mulcher 21" 6.0 lawn mower starts but won't stay running
clean the carb left over old fuel plugs the jets inside
Jun 08, 2012 | Craftsman Garden
My 12 year Craftsman lawn tractor with 20.5 hp B/S engine and 42" blades will not start. The starter turns over fine but no start. I don't know if it is igntion or fuel problem. I replace the...
Test for spark. Make sure the air filter is clean. Then make sure fuel is getting from the gas tank to the carb. Old rubber fuel line deteriorate and stop up small ports and parts in the carb. An inline fuel filter is a good idea on these larger engines. Sometimes, a larger B & S engine needs the OH valves adjusted to start easily and run properly. If after attempting to start, does the new plug get wet or even smell like gas? You should always use gas LESS than 30 day old. Gas goes stale like bread and milk. You can remove the fuel line from the fuel tank at the carb to drain old gas. You can also remove the carburetor bowl to check for water and sediment (which need to be cleaned out). Check these things and post back.
Sep 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Honda HRR216TDA lawn mower that starts and then stops and wont stay running i have replaced the spark plug and drained the fuel tank and checked all of the lines. Could the problem be a clogged...
More along the lines of a dirty carb. Replacements run about $32 online, sometimes less. If you know what your doing, remove the carb, pull the bowl and spray clean it with carb cleaner. You will see a small plastic screw on the side of the carb holding down a black plastic piece, remove the screw and pull the plug - spray that clean also. Recommend replacing all gaskets when reinstalling the carb.
Aug 08, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a craftsman DLS 3500 and my son put 2 part mixed gasoline in it and now it will not start. What should I do?
disconnect the fuel line at the carb and let it drain into something, then remove the screw(bolt) in the center of the fuel bowl and let the gas drain out...once it all removed, put the screw back in and hook the line back up..then remove the spark plug and use carb cleaner or something similar to clean the plug ...before you stick the plug back in after you have clean it, turn the engine over a few times to expel the gas oil mixture....refill the tank and try and start as normal...its probably going to some for a little while till all the oil is burned off
good luck
bill
Aug 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Craftsman rear engine riding lawn mower and it runs rough in fast mode. It also misses and chokes out when mowing. It has a 13.5 HP engine. I've changed the fuel filter and cleaned the carb, but...
Hi, don't burn it. Try these two other easy things that might give you some relief: First, clean the air vent on the fuel cap. Second,change the spark plug.
Best regards, --W/D--
Jul 16, 2009 | Briggs & Stratton 66set Panzer Tractor...
Tecumseh Sears Eager-1 6HP mower will not start.
I have an old craftsman Eager 1 self propelled 5.0 mower. I have been looking for a manual. The model # looks to be 131.4402 its hard to read. So far I have come up with nothing.
Jun 29, 2009 | Craftsman Garden
Mower will not stay running
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
May 14, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
532 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
