Question about Panasonic PT-51HX41 51" Rear Projection Television
TV won't turn on and red light blinks three times
  • Panasonic Master
  • 8,617 Answers
Thats the error code for the convergenec circuits needing repair. You can get PT51HX41 convergence repair kit at the following link which contains the two ICs and six feed resistors plus a CD with detailed instructions with pics on how to do the repair. Just look under the Panasonic repair kit category.
http://www.tvrepairworld.com/
Posted on Jul 13, 2009
What would cause the power light to blink red and the tv will not turn on
three times red light blink mean DC Alert which is related to system in internally & some time sound ic problum
Jul 12, 2014 | Sony KDL Televison & Video
Fujitsu plasmavision won't turn on
How many times do the red light blinks at a time? Count it. It is fault indication. After counting it, click here for details.
Dec 24, 2012 | Televison & Video
Sony tv won't turn on, light in standby blink three times
that is a master control board failiure, it is caused by having your TV on all the time, when the TV gets warm, you need to shut it off and let it cool down(that caused your problem) call sony and order a replacement part, it will take you about 20-40 minutes to install yourself.
Jul 19, 2012 | Televison & Video
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have a pt-47wxc43g panasonic projection tv and when i turn it on the red light blinks three times and it does not turn on.
Three times red light blinking indicates problem of convergence output chips are bad, tv has 2 chips that need to be replaced.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you technical info OR local tv repairman will do this job for you.
Thanks.
Dec 27, 2010 | Panasonic PT-47WX49 47" Rear Projection...
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I try to turn on the tv and the green light just blinks, nothing happens. After a few minutes it shuts off and the red light blinks two times and pauses. The red light blinks until I disconect from the...
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Dec 06, 2009 | Panasonic PT-56LCZ70 56" HDTV
I'm having a problem with my Panasonic PT-53wx52
Oct 30, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
210 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
