Question about Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV
How to change channels without a remote
I don't have the remote handy and wanted to know how to change channels with one. I cannot locate the channel changes on the TV itself. I may be looking in the wrong places.
SOURCE:
SOURCE: plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Posted on Aug 21, 2008
  • 10 Answers
chake to make sure it is hooked up right and not lose
Posted on Feb 02, 2009
eagle338
  • 4889 Answers
SOURCE: my panasonic 32 lcd tv tc-32lx60 will not turn off
Really sorry abou that. Here's the transcript.
http://www.fixya.com/support/c36637
I have been posting responses all the way through. But you were not able to see them, possibly due to some kind of bug
Posted on Mar 18, 2009
  • 4090 Answers
SOURCE: Panasonic Plasma no sound, can't change channel
Yes the control board would definitely be the offender here. But a word of caution. Oftenj when this board goes 2 other boards are also compromised and not always obvious at the time people think they can just swap the board out.
It went for a reason, not just old age. So it is better and cheaper in the long run to get a professional to check it out.
Also from a safety aspect, this is the High Tension area of the TV. Also be aware that radiation of the X type is in abundance at the rear of the tube. The TV must be grounded when opening ( but my advice is dont!) Let the professional do it
Posted on Sep 18, 2009
SOURCE: Can't change volume.
i'm having the same problem. i don't think it is the remote control as the volume/channel buttons on the front of the TV don't work either.
Posted on Jan 02, 2010
My remote wont work called about 3 weeks ago for replacementno response... and my tv is changing channels on its own,
You have to get nasty with the manufacturer at times to get what you want. No reason a remote can't be replaced in a few days; however, the problem seems to be the TV itself. If the remote is not active, and you experience channel changes automatically, it may be the TV receiver section alone. Call the company and mention that without the remote energized you have channel changes, they can run you through diagnostics to find the problem.
Feb 04, 2018 | Televison & Video
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 dollars.in the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
I have a visco TV and I cannot get it off of channel 1. The remote does not work so I bought a universal remote but it still won't work. I tried to codes for NEC and Polariod as suggested by others,...
There should be channel buttons on the TV itself, try using those. Also, you may want to try changing the input from the Cable Box.
I am curious as to why the remotes don't work. Also, how did it get onto channel one. Did you get the TV used?
Here is a link to the AV Science Forum. It seems other people have challenges with this TV as well.
http://www.avsforum.com/avs-vb/showthread.php?t=745952
May 19, 2011 | Televison & Video
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Tv changes channels when turned on.
Be sure your remote hasn't got a button stuck down which is changing channels. If not, take the batteries out of the remote. If this stops the channel changing there is probably some conductve material stuck across the circuit board
inside the remote. If this is the case you have to check inside the remote by openning it up.
Jan 28, 2009 | JVC AV-27530 27" TV
Changing the channel to av without a remote
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
Apr 20, 2008 | Televison & Video
Channels
If you have a menu button on the front of the Tv, you could search for an autoprogram or channel search menu and select that. Otherwise a cheap universal remote might be needed. You also want to make sure it is selected to receive antenna and not cable channels.
Sep 03, 2007 | Sylvania 6427FF TV
Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
