Goes through normal startup, but get a ''digital no signal'' box before login screen appears
  • 2,567 Answers
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Posted on Jul 13, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
XPS Gen2 / M170 display issue, mind boggling
What are the BIOS versions and what are the mother board revision numbers?
Mar 10, 2014 | Dell XPS M170 Notebook
Fujitsu-Siemens P15 TFT power/picture problem. it take time to turn on.
It does indeed sounds like the capacitors, I had this problem last year with a Medion monitor where it would turn on and off, when I spoke to Medion they did say that it would need a repair but at the time I wasn't enclined to pay the repair fees for something that may happen again!
Personally I would stick with your plan of getting a new monitor because my view on monitor hardware issues is that if it's happened once it will happen again even if you do repair it resulting in a lot of hassle!
May 27, 2009 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Loss of Signal
Check your connections from whatever you are viewing from.
Jun 13, 2017 | NEC PlasmaSync PX-42XR3A 42 in. HDTV-Ready...
I turn on my puter it goes to the user login and then logs off
I've run into this problem too often lately. So far I haven't managed to find a decent fix for it :( I've ended up having to backup the computer's data, reinstall windows, and restore all the data.
From the times I've seen it you get to the login screen, click on your user, get the "Loading personal Settings", a quick flash of the desktop, then back to the login screen saying "saving personal settings". It would do this in both safe mode and normal mode, so I was never able to try turning off startup software or services.
Booting to the windows XP disc and running a check disc might help, but from my experience with the problem you will probably need to reinstall windows. Hopefully someone else has a better idea.
Best of luck :)
Apr 13, 2009 | Microsoft Windows XP Home Edition
Sony vaio hangs on start up
Try to restore your PC.
Solution:
  1. after pressing the power button, start pressing "F8" before the windows startup screen appears.
  2. a menu will come out (in black and white) then select "safe mode"
  3. the PC will boot up in safe mode and you must login with administrator privilege.
  4. click start and go to:
-Programs
-Accessories
-System tools
-System restore
5. select on the dates that your system was still running
normally.
If this solution helps you, please rate me.
Thank you.
regards,
-engrkoiled-
Mar 26, 2009 | Sony VAIO (PCWA-A200)
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
  1. No start-up. Clicking sound from speakers
  2. solution
  3. Replace C922 and C923 (both 1000uF/16V). Also replace C924 and C925 (both 470uF/16V). on powerboard
JK electronics
Den Helder
document.getElementById('showwaitmessage').style.visibility = "hidden";
Aug 11, 2008 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Laptop screen.
Ok, Start the laptop in safe mode.
Press F8 (do it a few times) just after the initial screens have faded when you turn the laptop on.
You will get a Windows Startup screen.
Select Safe Mode and press Enter twice.
After you get into Windows, goto..
Start - - Run
Type msconfig and click the OK button
In the new window that pops up select the Startup tab.
Click the word Manufacturer and it will sort the list into order.
Scroll down the list and remove the ticks from anything where Microsoft is NOT the manufacturer. Also make sure to leave your Anti Virus software ticked. It may list itself as anything, but reading the text will let you know what is what. If unsure, then just leave the Microsoft boxes checked and the rest unchecked.
Click Apply
Then OK
OK any other boxes that pop up, and restart normally.
Post back and let me know if you can now get in normally and we can proceed from there.
May 16, 2008 | Acer Aspire 5100 Notebook
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
