Hard to see on the picture but it looks like a bernzomatic? Ive got a different model to yours and ive used it in all sorts of positions when brazing. I have noticed sometimes when its very cold weather, turning it upside down sometimes causes it to splutter and go out. That would be from liquid instead of vapour coming out. The lquid spraying out of the fill nozzle is probably due to a stuck valve or it may have some dirt in it. Try pushing the centre pin and out a couple of times releasing the gas.It may clear itself. Wear safety glasses and be careful when doing this!
SOURCE: Chevy Malibu 2003 cranks but won't start! I know
You might have a defective fuel tank pressure sensor!
You need to use triple refined butane exclusively. The phrase 'triple refined butane' will always be printed on the can if it is. 'Premium refined butane' and other lower grade butane types will make your lighter spit, sputter, and leak. You probably accidentally bought a can that looks just like the good stuff. Companies try to trick you - just be sure it says 'triple refined' and you're good to go.
