Dremel 395 Variable Speed Multipro Rotary Tool Kit
Problem for Dremel 395 Variable Speed Multipro Rotary Tool Kit
My dremel tool runs fine (the motor)but the
By pkayvon13 on Jul 12, 2009
My dremel tool runs fine (the motor)but the spindle stopped turning. Bumping it a few times will sometimes get it started again.
Comments:
Jul 13, 2009
- Thank you, kg4aau. I did open it up and saw that the tubing had broken apart but wasn't sure this was the entire problem or that I had to have the exact same kind of tubing. I wonder why dremel does not list this part (the tubing). I think maybe they don't want you to open the tool and try to fix it yourself. Thanks again.
Jul 19, 2009
- That's not the problem. The spindle (or whatever it is that turns with the tools on it) turns from plastic sleeve to end part but the motor does not seem to be attached. If I push the spindle toward the motor and spin the spindle everything turns (by hand) but it does not run when the pressure is off. Is there a part of the spindle that comes out of the motor and runs through dark plastic where you can't see it that could be broken?
Best Solution
posted on Jul 13, 2009
Very Helpful)
kg4aau
Rank: Guru
Rating: 87%, 117 votes
there is a tubing connector between the collet and the motor, they hot glue these together. i just go to the auto parts store and get a new piece of tubing and glue it the same way.you will have to partially disassemble it to replace the coupling. if you disassemble it the collet just lays in the housing on the motor side cut the tubing to the right length. a slightly smaller size won't need the glue.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Dremel 395 Variable Speed
Questions and Unsolved Problems for Dremel 395 Variable Speed
Do you recommend Dremel 395 Variable Speed Multipro Rotary Tool Kit?
Answer
Answer
Is the Dremel 2600 Project Table strong enough? The legs look wobbly and likely to collapse with a... (More)
Answer
I have an older Kango that has run out of fluid. what type of hydraulic oil should i put into it?
Answer
Need electrical schematic for Dremel Model 285 tool, looks like microchip is mechanicaly damage,... (More)
Answer
I have a Dremel Multipro model 395 the problem is that i plug it into the wall flip the power on and... (More)
Answer
My Dremel model 395 died after 15 seconds of work today while cutting a thin (1/8 in) piece of wood... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Rotary Tools Experts
Top Garden & Power Tool Repairmen
in San Mateo, CA
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
