I have a philip AZ2045 CD Player , but lately it can't detect the cd. Everytime I tried to play a CD it always written NO CD or CD EROR... Can anyone help me ,please ??
  • 1,254 Answers
Try using a DVD / CD disc cleaner. There is a lens on the driv which detects if a disc is inserted and to read the info on the disc. If its dirty, it wont read properly.
Posted on Sep 18, 2015
5 Suggested Answers
SOURCE:
silly girl
  • 513 Answers
SOURCE: reads no data on the player
Have you authorized the player? if not, or youre not sure, go here: http://www.docs.sony.com/release/Authorizing_flyer.pdf Theres also this documentation which notes your "no data" symptom - http://www.docs.sony.com/release/NWE405-407rev_note.pdf You will get a "no data" if you tried to format the player through windows explorer instead of through the player, and formatting it again, this time throught the menu in the player should fix this. Also there appears to be a transfer limit on the sonic stage software. something around 65,000, but who knows, maybe you managed to get there... Good luck
Posted on Apr 25, 2006
  • 4102 Answers
SOURCE: I try and play a track on my Sony nw-hd3 mp3 player and everytime it says 'error cannot play track'! Please help
hi have you istalled the correct software that came with it.
if you have then it could be that the tracks you have put on it are in wrong format.
you can change the format by using search engine and type in change format you need to change them to mp3 also delete whats on their and start again if you use something like limewire you can get tunes for free and after downloading them store them in file then you can drag and drop them onto your mp3
Posted on Jan 22, 2008
  • 476 Answers
SOURCE: i have a philips go gear 6 gb and i need help please i dont have the any cd
This solution applies to both jamilaht06 & Eppij.
Sounds like the firmware is corrupt or deleted.
Install and run the Philips Device Manager from the product CD.
Connect the player to the PC.
Wait for the PC to recognise the player then select the Repair/Restore option and follow the on-screen prompts.
This will format the player and reload the firmware.
NOTE: ALL TRACKS WILL BE DELETED FROM THE PLAYER
If the problem persists, it could be a faulty hard disk in the player. This is a standard Microdrive.
If this is the case, www.cheapestelectrical.co.uk have a couple in stock. (Only 6GB). They are not on the site, so you will need to e-mail them.
Posted on May 06, 2008
SOURCE: Philips SA1356/97 1GB mp3 player
hi my mp3 is philips your problam is same me.help me please my id s.hulangaa_77yahoo.com
Posted on Jun 11, 2010
Hi, i have a phikips dvd player and i keep getting bad disc when i try to play CDs
A bad disc detected by your Philips DVD Player shows that it is not able to read the data written on it because of the scratches on its surface.Please check it with a new CD and your problem is solved.Please don't forget to leave me a reply if you need further assistance.Your valuable feedback would be appreciated.Thanks.
Jun 11, 2011 | Philips DVP3146K DVD Player
Need replacement cd drive and casette drive for a philips az2045/17 or a used working replacement unit
At one time you could get a whole refurbished unit for $60. That pretty much makes yours not economically repairable, assuming the parts are all you need and the labor is free.
http://www.overstock.com/Electronics/Philips-AZ2045-CD-Boombox-with-Remote-Refurbished/866894/product.html
I'd look around on eBay for a similar replacement.
May 26, 2011 | Philips AZ2045 Cassette/CD Boombox
I buy a used technics sl-pg480a cd player and after i inserted a cd, there is "no disc" on display...i try with different cd's (mp3, avi,...) and it's always the same...i have opened a box and...
If it doesn't turn the disc it can't read the data and 'know' from that there is a compatible disc inserted.
You may have gotten hosed by the seller. Until you get it to play with a commercial music CD I wouldn't try anything non-standard or home-grown. It doesn't play anything but CD-A music so MP3 and AVI discs would not be recognized anyway.
Before you dive in and possibly wreck it, read this...
http://www.repairfaq.org/sam/cdfaq.htm
The manual:
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/model.SL-PG480A
Feb 20, 2011 | Technics SL-PG480A CD Player
Have just purchased a secondhand Philips 570 cd recorder and purchased TDK blanks for my first recording test.While the disc was still in the machine it recorded and played back ok.However,after removing...
Are you sure the TDK blank had either AUDIO/MUSIC somewhere written on the disc...if not, then that is the problem. On the other hand it it should not have recorded or played back as you said it did.
If it did have Audio/Music written on the disc, then first of all give the laser a clean by using either a disc cleaner or better still, take the cover off and gain access to the laser, using a cotton bud, diped in INDUSTRIAL METHALATED SPIRIT (usually coloured purple) do not use medical metholated spirit as oily additives could be added and smear the laser lens. Dry off the lens with the dry end of the cotton bud. Do not soak the cotton bud in the spirit, just a very small amount will do !!!
If it does not work now, try using other good named branded Audio/Music CD-R discs as there appears to be such a variation in the quality of CD discs which is well documented !
Did you FINALISE the TDK disc before you removed it from you recorder??
I have a feeling its the TDK disk.....I avoid TDK if I can...Try Sony or Philips Audio/Music discs, very few failures for me with those brands.
Hope this has ben of some help...good luck
Sep 12, 2010 | Philips CDR870 CD Recorder
No Disc Error in Philps FWD17 with DVD and MP3-CD playback system
The problem with the system Philips FWD17 shows NO DISC for certain CDs which wont play. With regard to DVDs it doesnt recognise them at all. The disc spins and then stops showing NO DISC
I have replaced the lens with the same type and model SF-HD65. It still doesnt detect DVDs
Please advise.
Regards,
Gerry
E-Mail gerardf1960@gmail.com
Feb 22, 2010 | Philips HTS3400/37 System
Philips go gear dozn't play anythng
you muat have gotten a cd alongwith the player...install philips device manager from the cd and connect the player to system.the program must detect the player and repair it by itself.
Sep 05, 2009 | Philips GoGear HDD6330 MP3 Player
E80041395:IDISPATCH error #4501
roxio player is a video player not a audio player.and is you burn your audio cd by nero software by audio section.
Jun 23, 2009 | Averatec 6200H Notebook
Player won't read cd's keeps opening door
This model has a belt used for loading the cd mech, after you push play if the belt is slipping or gone,the door will open, if you take the cabinet off eith power off and traopen, look at cd mech you see a belt, it may be loose or gone
Oct 25, 2008 | Yamaha CDC-565 5-Disc CD Changer
Stuck on start screen
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Then get the firmware upgrade
Jun 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Can't read the disc !!
I replayced dvd cd-rom myself it's very simple repair and it cost me $20.00 for new dvd rom. Don't buy CD-RW but just simple black dvd-rom.
I hope this will get you going again.
Jan 28, 2008 | Bose (321GS) System
89 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
