Question about Hayward Pool Products Hayward 400k Ng H Series Spa & Pool Heater
I have a H350ED1 , the heater seems to light and get hot, the water is circulating but never gets warm even after one hour
  • grank177 Jul 12, 2009
    the heater gets very hot, can not touch it , very hot, the water is not getting warm though
  • 3,230 Answers
It seems that the heater not getting hot properly, means its a time to changing the heating element.
but first you try some cleaning, clean the heating element.
note. unplug this unit before yo do anything...
Good Luck!!
Thanks
Posted on Jul 12, 2009
  • Mukesh Kumar Jul 12, 2009
    Well, then it's a good news....
    try cleaning the heater element....
    post back some result after cleaning the element.
    Thanks
Why is my heater blowing cold
Most likely it is the heater control valve that shifts air from blowing across your heater core to your air conditioner core.
If your fan works and your car is fairly new..meaning your heater core isn't dirty and full of craap...then it is the climate cotrol valve.
If you are lucky, it might be a thermostat that is bad and blocking hot water from entering your heater core. Bottom line, if hot water doesn't circulate thru that little heater core, you won't get heat.
You might be able to look under the hood and grab the hot water lines that go thru the firewall and feed your heater core. If they feel cold to the touch after engine has warmed up, then you aren't getting circulating water to the heater core. If they feel nice and warm, then the heater core is fine, but your climate control valve has closed off the fan that blows across the core to disperse heat into the cabin
Feb 24, 2015 | Cars & Trucks
No heat in audi A4 1.8 water gets hot and circulates
Are both heater hoses hot when the heater is on? Look for the water control valve to see if it's letting water into the heater core. The core could be plugged too.
Jan 09, 2014 | 1999 Audi A4
Heater just buts out cold air
Any leaks in the system(do you have to add water regularly?)? Check the heater control valve- it allows hot water to circulate through the heater core. Could be bad.
Jan 14, 2013 | 1999 Ford Taurus
My heating is not working properly it starts and then after a while radiater light goes on and off n then heating stop working but i get hot water ok
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though it may be hot and seem to be running. In this cause the pump can sometimes be taken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in more detail.
Heating Circulating Water Pump Problems
heatman101
Feb 23, 2011 | Heating & Cooling
I can't seem to find the thermostat in my 2000 Chrysler LHS 3.5 L Is it in the manifold at the end of the upper radiator hose or elsewhere? I've seen so many answers and haven't yet found a solution. A...
If you were to take the upper radiator hose off the engine, and look into the resultant hole, you would see the thermostat.
The thermostat on all cars blocks water leaving the engine and going to the radiator, until the thermostat warms up enough to open.
While the thermostat is closed, water circulates through the heater hose, straight back to the inlet of the water pump. This circulation prevents hot spots, distributing the heat evenly to warm the engine up, and also brings that warmed water to the thermostat.
When the t-stat gets hot enough to open, water leaves the engine instead of circulating through it, and that allows cool(ed) water to flow from the radiator through the bottom hose to replace the water that left through the upper hose and t-stat.
The stub that the upper hose attaches to on the engine should be part of a small housing that is bolted to the engine. Removing that housing is how you remove the t-stat.
Aug 05, 2010 | 2000 Chrysler LHS
Two Rinnai's in series, large house, using circulater with electric pump connected to 2 gallon electric water heater. Problem is the Rinnai's seem to be firing almost constantly, apparently due to some...
Your circulator provides the draw necessary to fire the heater. You are defeating the purpose of this kind of heater by circulating the water. Add a second heater to fix this engineering fault.
Jan 05, 2010 | Rinnai Digital Remote Water Heater Control...
I have installed a 4 gallon inline water heater close to the bathroom. The main hot water heater is at the other end of the house. Now the hot water in the bathroom runs luke warm when the washing machine;...
you don't have a circulating line in it,, there for it is pulling the hot only,, when you have the 2 systems you have to have it circulationg or take 1 out, it being it is hot water they will vapor lock,, meening no hot water , you could get a circulating pump that actually hooks to the cold and hot side under the sink far away from the water heater and it has a timer on it that will circulate the water at certain times of the day,,, this would solve your problem
Jul 02, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Pool heater will not flame
sounds like a flame rectification probelm...look in the manual for solutions
May 30, 2009 | Hayward H Series Millivolt 250,000 Btu...
Dishwasher
Wash water isn't hot even after we run hot water in sink before turning on dish water. However rinse water is hot. It appears the heating element is not working on wash but is on rinse?
Dec 19, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Hayward Pool Products Hayward 400k Ng H Series Spa & Pool Heater  Logo
78 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
