Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
KM-500MAH water keeps cycling thru when in ice making mode.
Water keeps cycling thru the machine even when the machine is in ice making mode. Also makes loud gurgling sound when water is cycling thru the machine.
    Champion:
  • 233 Answers
If this is a water cooled machine, the head pressure flow controller need to be replace/adjusted.
Posted on Jul 12, 2009
Hoshizaki ice machine model km 900mwh low side suction line has ice building up on it all the way to the compressor
Is it making ice? Frost on this line is not that uncommon as it is colder than the air around it. Make sure you have good water flow over the evap plates. machine may just need a good chemical cleaning.
Jun 14, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Ice machine keeps freezing on the ice trays
If you are referring to the ice not clearing the evaporator plates, usually the defrost cycle is too short. Check that by watching the machine and when it goes into the harvest mode, see if all the ice comes off. If not, lengthen the cycle.
May 15, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Ice machine 3 beeps
signal means freeze cycle is over 60 minutes. Look for: stuck float, water valve leaking water into sump, hot gas valve leaking hot gas into the cool side of the refrigeration system. start there.
Dec 04, 2013 | Hoshizaki Commercial Freezer KM-500MAH
KM-500MAH won't go into harvest mode
The float switch controls the harvest cycle.
Apr 22, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine model KM-450MAB water runs constantly even on freeze cycle. Water is very cold.
Hoshizaki machines have a water inlet valve that can stick in the open position. This will cause the machine to do silly things. If you can turn the machine off and you can still hear water running, the valve is stuck open. It is an easy fix. Water valve only has 2 wires going to it and 2 water lines. One inlet and one outlet. Just turn off water and kill power at the breaker before doing any work.
Hope this helps and good luck.
Try Rick and Restaurant Parts and More in Ohio for a replacement valve. 1-888-814-1110
Apr 01, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Ice cube cycle time very high
i suspect a defective liquid line or pump down seleonid coil. just make sure you hear the "click" when it starts up if not the selenoid coils could be defective. also verify that the condenser fan is running,because if not you are short-cycling on high head pressure. please contact if you need any additional info
Jun 11, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki KM-500MAH not making ice
Look at water solenoid valve when the unit is running in ice mode. Check to see if the water is shuting off completely. If the water valve does not close properly it will keep adding a little bit warm water to the ice a slow down the ice production.
Sep 21, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
243 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
