Question about IBM ThinkPad X30 2672 Notebook
Ibm think pad t30
Cannot connect to internet. gives message a network cable is unplugged. since it is wireless which cable? regular computer works fine. novice here
please help
pandora
    Brigadier General:
  • 6,966 Answers
To my knowledge, your laptop (IBM ThinkPad X30 2672) does not have any built-in WiFi. It's modes of connection are IrDA, modem, Ethernet, USP, Firewire aside from the regular serial & parallel. This would indicate that if you are wireless you either have a USB dongle or PCMCIA card. Please post back with your WiFi brand/model and your Operating System. Further, please post back likewise your WiFi AP/Router brand/model.
The message "a network cable is unplugged" pertains to the absence of a lan cable connected to your Ethernet port.
Good luck, kind regards and will await your second post.
Posted on Nov 16, 2007
  • Louie  Role
    Louie Role Nov 16, 2007
    Oooopppps, sorry the "USP" should read USB.
T30 thinkpad wireless network switch
Locate the wireless icon lower right on screen.
Right click on it and then click on enable.
Jun 20, 2014 | IBM ThinkPad T40 2373 Notebook
IBM T30 Thinkpad 2366 wireless network I inheirited a IBM T30 laptop from my wife. She haad it loaded up with so much **** and it was extremely slow. My fix was to format the drive and reinstall Windows...
You need to download the drivers for your Netgear.
The IBM drivers also need to be found,Depending on your model, it may have WiFi. From IBM spec sheet:
  • 10/100 Ethernet installed on the system board
  • Selected models will have Intel Wireless and modem Mini PCI combo cards
  • Selected models will have CISCO Mini PCI card
  • Selected models will have Bluetooth communication daughter card
Nov 01, 2011 | IBM ThinkPad T30 2366 Notebook
Wifi on ibm thinkpad t30
The wireless driver may got corrupted or uninstalled.
Go to Control Panel - System - Hardware - Device Manager - Click on Network Adapters and if the wireless card is listed click on it to see if it is working and enabled. If not then reinstall the wireless driver.
Aug 13, 2009 | IBM ThinkPad T30 Motherboard 91P7695 -...
Network runs only in battery mode - when power supply is connecte
that may be due high band width and for more info contact http://tinyurl.com/m7ghqz
Jun 17, 2009 | IBM ThinkPad T30 2366 Notebook
Dont know how to turn on the wireless to my ibm think pad t40
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.moz-screenshot.jpg0d7fbfc.gif
Jun 08, 2009 | IBM ThinkPad T30 2366 Notebook
I am unable to establish a wireless connection via thinkpad.
What kind of a message do you get? You may have to turn on radio. You can make sure it is enabled.  under connections, right click properties, if it is disabled, click enable, try to repair, delete it and then look for new hardware. Good Luck
May 25, 2009 | IBM ThinkPad T30 2366 Notebook
I have a T30 IBM Think Pad and cannot find the wireless switch. Can someone help me?
I don't think the T30 has an actual physical switch for the wireless. The ThinkPad button will show you how to do the wireless setup/repair. If you have Bluetooth on it, the Bluetooth indicator should be near the hinge.
Feb 24, 2009 | IBM ThinkPad T40 2373 Notebook
Laptop.. cannot connect to internet
if you want to use wireless connection you have to have a wireless router, and you connect your internet cable into the router, so after you can have a wireless connection with your laptop and his wireless card, and you can work with your laptop everywhere in your house.
you can buy a wireless router in every computer shop.
last thing if you have a desktop PC you can connect a new internet cable to the wireless router (type RJ45)
I hope this helps
Please rate accordingly
Thank You
sserpentio
May 03, 2008 | IBM ThinkPad T30 2366 Notebook
Wirless internet not working
If the router has a block of 4 ports (or more) on the back and one is not used yes -- the separate port which may or may not be connected to the Internet Service Provider's equipment cannot be used for this purpose. There is only one connection point on your computer.
Any connection requires
a unique IP address on the correct Subnet
the appropriate subnet mask for the network segment
the appropriate default gateway for the subnet
and one or more DNS addresses so names like
www.fixya.com can be accessed
the following work on both the wired and wireless adapter
this can be checked from a command prompt window using the command -
ipconfig /all
A second command can be used to determine of the network adapter is communicating with the router the command is
ping (default gateway)
where (default gateway) is replaced by the default gateway
returned by the ipconfig command above
could be 192.168.0.1 or something close in a home network.
4 timeout messages indicate failure and 4 message with elapsed time in ms (milliseconds) is success. the results can be mixed, but should not be in this case.
If you need additional instructions to issue these commands ask in a reply to this message and I will send you the detailed instrictions.
Record information returned by the above tests and return in a comment with the current problem description and I will respond with additional steps and questions or possibly a solution.
Thanks
Dec 16, 2007 | IBM ThinkPad T30 2366 Notebook
IBM Think Pad T30
Off which thing u r talking about??? i cannot understand you question! Plz be clear about the questions so we can assist you!
Which software your lappy was running when you got the message? and which operating system you r using?
Dec 08, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad X30 2672 Notebook Logo
229 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
