Question about Cycling
Coaster brakes noisy when you first stop pedalling. bearings are all good
  • 34 Answers
The pads inside the hub could be worn or the hub could be adjust incorrectly. How do you know that the bearings are all good. Did you overhaul the hub? If so, make sure your reassembled the hub correctly.
Hope this helps!
Posted on Jul 22, 2009
Aseemble a coaster brake on a bicycle
Ken, Check the attached links,instruction and guides on removal and install coaster brake. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Coaster Hub Overhaul Pedal Brake Hub
How To Install Cog On Coaster Brake Hub
Bicycle Coaster Brake Repair and Service
Oct 01, 2014 | Husky 26"" x 2.125 Industrial Chrome...
Is the chain suppose to spin backwards on all mongoose bikes ?
Only if it has a freewheel, it will make a slight clicking sound when pedaled backwards. The coaster brake models do not. If you pedal backwards and the cranks locks up tight after moving a few inches then it is a coaster brake bike. These also have a brake arm on the rear hub, attached to the frame.
Aug 01, 2014 | Cycling
I have a hyper pro model bmx bike and My back rim tightens up when I start to pedal
Do you mean that the back wheel becomes hard to roll when you start to pedal? And is this tightening up coming from the center of the wheel (bearings, hub, axle), and not from the rim or tire rubbing on something like the brakes or the bike frame? I am guessing a lot here from your breif description of the problem, but if I have that right you will have to remove the rear wheel and partially disassemble the hub. The locknuts that should constrain the space taken up by the bearings and the mechanism that allows you to pedal or coast (assuming this is not a fixed-gear bike) are either loose or adjusted too tight. It is also possible that the coaster mechanism has another problem. Good luck!
Oct 23, 2012 | Cycling
When coasting the pedals keep moving so you have to continue to pedal and when peddling backwards the bike goes backwards, how do I stop this?
I assume that this bike normally has a coaster brake. If so, your coaster brake mechanism (inside the hub of the drive wheel) is jammed or broken. You will have to disasssemble the wheel hub. This bike might have a coaster brake on both rear wheels or maybe just one side. Lift both rear wheels off the ground and turn them independently to determine which side the problem is on.
Sep 18, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Gmc Suburban random brake fade on abs system when brake pedal at end of 'travel' and vehicle almost stopped, brakes shudder and become mushy with poor braking power.
You Have A Bad Wheel Bearing. Inside the wheel bearing is a speed sensor, The Only Good Way To Change the speed sensor, Is To change the wheel bearing, Because , more than likely , the bearing is failing also. Good Luck
Jan 18, 2011 | GMC G1500 Cars & Trucks
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
03 alero noisy frontend, noisy front/rear wheels releasing brakes
I have had these do this from the calipers. They are made of aluminum right?
Jun 30, 2010 | 2004 Oldsmobile Alero
Huffy beach cruiser back wheel grinding when im coasting?
you can tighten the coaster brake by turning the big lever on the back tire
Jun 30, 2009 | Cycling
Why does my new bike's back wheel not spin easily?
if brake and aligmen t of wheel is good the bearing ajustment is too tight remove the wheel loosen the nut on each side not too loose just so it turn freely with no play in the wheel let me now pierre
Dec 14, 2008 | Mongoose Butterfly Summer 12" Girl's Bike
Cycling Logo
115 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
